Indigo 3.0 - OpenCL error
Come here for help & support.
7 posts • Page 1 of 1
Bosseye
Post by Bosseye » Wed Jun 22, 2011 11:22 pm
Ok, Indigo 3.0 trial:
If I enable GPU acceleration then I only get a black screen, no image, SPP does not increase despite render time increasing. Works fine if GPU acceleration is off.
CUDA-Z is reporting CUDA compute capability of my card (Nvidia Quadro 4000) as 2.0, so should work considering Indigo apparently needs at least compute 1.1
ENSLAVER
Re: Indigo 3.0 - Black screen with GPU acceleration
Post by ENSLAVER » Thu Jun 23, 2011 12:07 am
Check the render log, try with an extremely simple scene.
Bosseye
Post by Bosseye » Thu Jun 23, 2011 12:45 am
Render log returns this using a basic scene containing a cube only - presumably the last line is the most important:
Detecting available GPU(s)...
Device number: 0
Memory: 2014 MB
Type: OpenCL
Scene file path: 'C:\Users\adown\AppData\Roaming/Indigo Renderer/default.igs'
Sky zenith luminance: 3387.095215 cdm^-2
Rendering with GPU acceleration
Forcing bidirectional=false, hybrid=false, batched=true
Light luminous flux (geometry name=EnvSphereGeometry): 5.746E+009 lm
Building Object Tree...
1 objects.
calcing root AABB.
AABB: (0.236831, 0.292659, 0.000000), (3.618678, 5.213458, 2.038000)
max tree depth: 2
reserving N nodes: 1(8 B)
total nodes used: 1 (8 B)
total leafgeom size: 1 (8 B)
Finished building tree.
AutoFocus: setting camera focus distance to 5.76820 m.
Num buffer layers: 1
Master buffer size: 20.960 MB
Auxiliary buffer size: 48.307 MB
Settings:
Image width: 958 px
Image height: 466 px
Internal image width: 1932 px
Internal image height: 948 px
Verbose: false
Display period: 10.00000 s
Image save period: 60.00000 s
Frame upload period: 40.00000 s
Splat filter: FastBox
Downsize filter: mn_cubic, blur=0.33330, ring=0.33330, support=4.00000px
Render region: false
Supersample factor: 2
Metropolis: false
Bidirectional: false
Hybrid: false
Aperture diffraction: false
Post-process diffraction: true
Auto setting number of threads to 8.
Finished initialisation (Time Taken: 0.07843 s)
Time to render thread start: 0.07898 s.
Starting threads... (num threads: 8)
OpenCL build log: :5: error: ilegal address space on image or sampler type
__constant sampler_t l1lll11l1l1 = CLK_NORMALIZED_COORDS_FALSE | CLK_ADDRESS_CLAMP_TO_EDGE | CLK_FILTER_NEAREST; inline float4 ll1l1l11lll(read_only image2d_t texture, const uint ll1l1lllll1) { const uint y = ll1l1lllll1 / OMTX; const uint x = ll1l1lllll1 % OMTX; return read_imagef(texture, l1lll11l1l1, (int2)(x, y)); }
Error initialising GPU ray tracer: Build failed
Not sure what that means...
Bosseye
Post by Bosseye » Thu Jun 23, 2011 2:40 am
Updated Nvidia Drivers to latest version 275.36 - works like a charm now. Also in the GPU dialogue box its showing as Quadro 4000 (CUDA) rather than Quadro 4000 (OpenCL).
Much much faster too :)
Thanks for your help.
Post by Zom-B » Thu Jun 23, 2011 10:21 am
Bosseye wrote:Updated Nvidia Drivers to latest version 275.36 - works like a charm now. Also in the GPU dialogue box its showing as Quadro 4000 (CUDA) rather than Quadro 4000 (OpenCL).
Latest Drivers are 275.50 but don't let us get picky :lol:
Does your GPU also has a OpenCL option in the dropdown? It should have one! Does that work now?
Bosseye
Post by Bosseye » Mon Jun 27, 2011 9:07 pm
Pshaw, whats in a couple of numbers eh? :lol:
Hmmm, it does have the OpenCL listed as an option in the drop down box - but it doesn't work.
OpenCL mode renders a strangely distorted version of the model, but does so at a crazy level, sometimes around 12000k compared to around 4000k for the same scene in CUDA mode. See below.
For the black background scenes as an example:
CUDA - 2 minute render, 370spp, 4097k
OpenCL - 40 second render, 370spp, 11900k
CUDA enabled, sketchup black background, sun & sky off
OpenCL enabled, sketchup black background, sun & sky off
CUDA enabled, sketchup sun & sky background
OpenCL enabled, sketchup sun & sky background
Bosseye
Re: Indigo 3.0 - OpenCL error
Post by Bosseye » Fri Jul 08, 2011 1:09 am
Anyone got any thoughts on the OpenCL issue?
