This is the second time I encounter the same issue with two different files.
This morning I ran test renders trying different materials, all of the sudden Indigo failed to launch from sketchup. If I try to export my view and open it manually from Indigo the following message appears:
FAILED TO LOAD
granpermanen
Re: FAILED TO LOAD
I am aware this is just the mesh folder, when I open the main file manually my processor goes to 100% and nothing happens. It is as is Indigo would not be able to open the file and then the machine crashes. I use a powerful I7 processor, so muscle is not an issue.
When I use a different file Indigo works fine. It is as is my file became corrupt....
granpermanen
Re: FAILED TO LOAD
W E I R D
I noticed my file started failing when I created the last material.
I used the "assign preset" for a diffuse plastic. I just opened the model, deleted the last material I used and it works AGAIN. Is this a bug? Am I loosing it, too much caffeine?
