Can't have physical sky+sun and light materials.
Come here for help & support.
tlehmann1996
Post by tlehmann1996 » Fri Aug 27, 2010 12:48 pm
Why wont indigo let me have sun coming through a window and have objects with light emitters at the same time?
Dell Studio 1737 on Vista64
Intel Core 2 Duo CPU T6400 @2.00GHz 2.00GHz
4GB RAM
Re: Can't have physical sky+sun and light materials.
Post by Borgleader » Fri Aug 27, 2010 12:56 pm
tlehmann1996 wrote:Why wont indigo let me have sun coming through a window and have objects with light emitters at the same time?
What do you mean it doesnt let you? Because...it should. Can you be more specific about the error you're getting?
tlehmann1996
Post by tlehmann1996 » Sat Aug 28, 2010 1:46 am
The second picture I have it set to Physical Sky+Sun and has no lights. The first is what happened when I added four squashed spheres with light emitting materials, without changing any other settings outside of materials. When I hit render the environment option switches from physical sky+sun to background color, and when I switch it back and render it again, it changes to bg color again.
4GB RAM
tarikb
Post by tarikb » Sat Aug 28, 2010 2:31 am
Can indigo have both ( sun and ligh materials) in one scene? How?
Skindigo
Post by pixie » Sat Aug 28, 2010 2:59 am
tarikb wrote:Can indigo have both ( sun and ligh materials) in one scene? How?
You would have to set the inner lights strenghs way up so that they can have a real impact on the scene, and then use layers to tune them up.
tlehmann1996
Post by tlehmann1996 » Sat Aug 28, 2010 8:08 am
Turning up the light strength wont do anything though, will it? I need both sun and lights, and right now I'm getting just lights.
4GB RAM
Post by Zom-B » Sat Aug 28, 2010 8:25 am
The eternal suffering... it isn't very easy.
Each light material needs to be aligned in illumination strength to fit with the other sources.
If you use Sun as lightsource (that has fixed illumination strength) you need to align your
meshlights! Simply Reduce the strength of the emitters...
tlehmann1996
Post by tlehmann1996 » Sat Aug 28, 2010 9:00 am
No matter how much I change the power of the light material, nothing changes. They are either on or off. The only way I could do that was to turn gain completely off, then the lights went off and the sun came in. But when I turned gain up even to 0.0001, the lights are back to their usual power and the sun is gone...
4GB RAM
Post by Zom-B » Sat Aug 28, 2010 9:11 am
Seems Reinhard tonemapping is the evil here :)
change to linear or camera tonemapping.
Light Sources also can be also restrained using the "Emission Scale" feature.
tlehmann1996
Post by tlehmann1996 » Sun Aug 29, 2010 4:29 am
I tried setting it to both camera and linear, but still no sun. Any other ideas?
4GB RAM
Post by PureSpider » Sun Aug 29, 2010 4:52 am
Seems like you guys get him wrong...
Looks like an exporter issue.
As soon as he turns on the lights, the environment changes from sun to black background!
Nothing to do with Reinhard or whatever!
tlehmann1996
Post by tlehmann1996 » Sun Aug 29, 2010 6:26 am
If it's an exporter issue, how can I fix it? I've had this problem on all of my interior models and have just dealt with it.
4GB RAM
Post by Zom-B » Sun Aug 29, 2010 9:20 am
easiest way to get this solved is to reduce your scene to room + lights (no furniture) and post the scene here, so we can have a look.
Its very uncommon that new users just find critical bugs... its more often a wrong understanding of the exporter ;-)
tlehmann1996
Post by tlehmann1996 » Sun Aug 29, 2010 11:10 am
Do you need a render or settings? If so, what settings do you need?
4GB RAM
Post by Borgleader » Sun Aug 29, 2010 11:23 am
tlehmann1996 wrote:Do you need a render or settings? If so, what settings do you need?
All of them just make a copy of your scene file (c4d/max/blend/...) in the copy take out all the furniture, leave only the walls /lights ... like zomb said, compress it to .zip and post it.
