"Metal Pipe-thing..."
madcoo
Post by madcoo » Thu Feb 18, 2010 8:18 pm
Hi all!
New project coming up : I'm going to work on industrial pipe parts kind of things (I don't know what the name is in English...)
:wink:
I'm looking for photorealistic effect, but still can't get close enough to it.
Any idea about how I could make the object look more "real"?
I put the pipe-thing in a cube, and left open the roof in rectangular shapes (Exit Portal).
- Maybe a closed room with lights would look more like a studio photo?
- Maybe adding other objects around it would make the reflections look better?
Many thanks guys!!!
:D
Visit my website!
http://www.fairview-3d.com Studio 3D
Re: "Metal Pipe-thing..."
Post by suvakas » Thu Feb 18, 2010 9:07 pm
Why not to use a studio setup + some kind of HDRI environment for reflections?
A good studio setup always looks professional for stuff like this.
Bunch of pipes in a closed sunny box is a bit surreal.
madcoo
Post by madcoo » Thu Feb 18, 2010 9:16 pm
Thanks Suvakas, I'll try a studio setup (closed room with emitting objects for lamps).
Do you have a link for good (and free) HDRI maps on the web?
Many thanks again!
:wink:
Visit my website!
Post by CTZn » Thu Feb 18, 2010 9:47 pm
There is another solution djegoo: more work on the environement.
Can you see the flat horizon reflected in your pipes ? This empty space is a realism killer, try to populate it !
If your pipe is a reflecting object, then the reflected objects are critical to underline the shape, may them be studio lights. If there are no "identities" underlying the pipe's curves then the image results flat.
It's also about blocking light as you did with that big structure in the background, only that it has a low impact on the reflections.
The modeling is nice so far :)
Post by suvakas » Thu Feb 18, 2010 10:13 pm
No need to model a room. Just use a curved plane for backdrop and some rectangular planes for the lights. You know, the classical studio scene.
Can't remember any HDRI links atm, but search the forum. There should be some good links in some threads.
But I think that any random HDRI should do it cause you only need it for reflections. It also may even work out without the HDRI.
madcoo
Post by madcoo » Thu Feb 18, 2010 10:37 pm
Many thanks for your kind and very helpful replies.
I'll try your solutions and will keep you informed with some new pics as soon as possible!
Cheers!
:wink:
Visit my website!
Post by Pibuz » Thu Feb 18, 2010 11:05 pm
djegoo
Post by djegoo » Thu Feb 18, 2010 11:14 pm
CTZn wrote:There is another solution djegoo
PRESENT!! (oh back to school!)
It's Madcoo :) not me.
Yep i agree witl all is said, studio setup, and an env map for reflections.
keep goin
madcoo
Post by madcoo » Thu Feb 18, 2010 11:51 pm
Thanks for the great links Pibuz!!!
Really cool!
:wink:
And thanks for your encouragements guys !!!
:D
Visit my website!
madcoo
Post by madcoo » Fri Feb 19, 2010 12:59 am
I thought I could share back...
:wink:
What do you think about creating a new topic called "Royalty-Free HDRI resource" where everyone in the forum could post free HDRI links?
http://www.debevec.org/Probes/
http://www.deviantart.com/deviation/10152791/
http://www.deviantart.com/deviation/10036562/
http://www.deviantart.com/deviation/9597501/
http://www.luxrender.net/forum/viewtopi ... =17&t=3005
http://www.digitecture.org/index.php/20 ... available/
NOTE: All these links enable you to download content directly, but I haven't used the files yet, so I'm not guaranteeing the quality at all...
Visit my website!
Post by Headroom » Fri Feb 19, 2010 2:52 am
That "Metal Pipe Thing" would be called a Valve.
Usually valve bodies are made of either cast or forged metal. Looks like Stainless Steel in this case. Either way the surface is usually not as smooth and shiny as in your render. Also the transition between the pipes seems a little to sharp considering the manufacturing method for these kinds of things.
The hexagonal shape is usually there to accept a pipe wrench. As such it is unusual to have a ribbed surface as that is going to be deformed by the tool used for installation.
If you use an HDRI try to find something "industrial" looking.
madcoo
Post by madcoo » Fri Feb 19, 2010 3:05 am
Wow!
Many thanks for these useful pieces of information!!!
I'll keep this in mind when modelling and working on the materials!
:D
Visit my website!
Post by suvakas » Fri Feb 19, 2010 6:31 am
Headroom wrote:That "Metal Pipe Thing" would be called a Valve.
And for some reason it reminds me that I need to finish HalfLife 2 at some day. :D
Soup
Post by Soup » Fri Feb 19, 2010 9:55 am
madcoo wrote:I thought I could share back...
:wink:
Check the sticky at the top of general: HDR 2 EXR + some HDR sites :mrgreen:
Also, Suvakas - Finish it! You won't be disappointed.
Post by CTZn » Fri Feb 19, 2010 4:20 pm
Ah yes, apologizes to both of you. It happen that I don't check the user names when I type them :oops:
Users browsing this forum: Google [Bot] and 198 guests
