"Astra. Was dagegen?"
Post by Zom-B » Tue Oct 24, 2006 2:31 am
I started to model a Beer Bottle of the famous Beer Brand Astra, over here in Hamburg - Germany... :D
Indigo 0.65 - Reinhard 1, 1 - burn 0.65.
IOR of the bottle is 1.4 and of the beer its 1.5, don't know if this is perfect...
At the moment I try to scan the label (got to find someone with a scanner first^^),
but at the and I think I have to "model" it to get the golden Part shiney...
here are som examples of the great Astar print advertise:
Image Image
Image Image
SmartDen
Post by SmartDen » Tue Oct 24, 2006 2:58 am
Very nice!
But the bottle cup is too glossy. Make less exponent or use another nkdata
Post by Zom-B » Tue Oct 24, 2006 3:13 am
I tried some random bumpMap image at Aluminum...
Had to check for a more golden nk mat, less exponent and do a custom Bump :)
atmmatt
Post by atmmatt » Tue Oct 24, 2006 3:58 am
Zom-b Is the bottle hollow inside with water? If it is, the wall of the bottle looks a little thick. I know that it's modeling but might it affect the rendering of the inside beer?
p.s. I vote for the second advert :D
"To be, or not to be" That is a question?
manitwo
Post by manitwo » Tue Oct 24, 2006 4:08 am
Try this:
IOR water: ~1.33
IOR glass: ~1.52
This diagram shows the way to archieve the most correct liquid+glass result: (by Thomas An.)
(http://www.maxwellrender.com/forum/view ... hp?t=17147)
Post by Zom-B » Tue Oct 24, 2006 4:44 am
Thanks a lot manitwo.... this should help... after I understood this O_o
somehow... someday...
This seems like faking the model, to archive a real looking result :?
is the Capillarity the "surface tension", and if it is, why with glas material O_o
Kosmokrator
Post by Kosmokrator » Tue Oct 24, 2006 5:14 am
oooohhh too hot beer.....i mean the comercial blonde chick.... :wink:
Post by Zom-B » Tue Oct 24, 2006 6:41 pm
I knew you guys would like the blonde... who woudn't?
(Text translated: "somewhere the text has to be!")
Here is a small Update for the Bottle, still in the way I started,
got to otimize colors of bottle & Beet, and than try manitwo's
tip for the model...
I found out, that the IOR of beer is 1.345 :wink:
The Cap isn't NK Mat for Gold, but "Ni3si.nk"...
btw: Rendered with 0.66 and it seems to be much faster :shock: got to test this!
***EDIT***
I benchmarked v0.65 compared to 0.66 and the new one seems to be "only" 1% faster :wink:
Post by OnoSendai » Tue Oct 24, 2006 11:13 pm
Yo,
I'm gonna have a think about how to render this correctly, the technique of Thomas An will almost certainly not work correctly with Indigo.
Post by Zom-B » Wed Oct 25, 2006 12:36 am
Ono-Sendai wrote:Yo,
Would be nice if you could drop some Lines about this Topic Nick :)
At the moment I'm very happy with the rendering!
I stared long time at the bottle and compared what I saw to the Rendering...
now bottle is empy and I need a new one :lol:
Only the part under the Cap, these sharp edges shoud be much softer,
like in the first post render, but I think the IOR of the Glass is fault :wink:
Post by OnoSendai » Wed Oct 25, 2006 12:43 am
I think i have a good solution, i'll write about it tomorrow
Post by OnoSendai » Wed Oct 25, 2006 12:45 am
haha :)
manitwo
Post by manitwo » Wed Oct 25, 2006 12:56 am
This is the original thread on the maxwell-forum (for those who haven't
seen the small link posted beneath the ThomasAn diagram :) ):
and the long version:
http://www.maxwellrender.com/forum/viewtopic.php?t=2906
:shock: :twisted: i can't wait :D
arneoog
Post by arneoog » Wed Oct 25, 2006 3:20 am
Doing it the Thomas An-way is creating a much more messed up scenario :)
I'll post my test when it's done rendering if you want
Anyway, good so far, Zom-B 8)
Post by Zom-B » Wed Oct 25, 2006 4:11 am
thanks arneoog :)
would be great if you could post a "Thomas An-way" testrender :D
btw: your Cola bottle is done also the "real life" way, with thik glas,
and a model inside for fluid, isn't it?
What IOR do you used for the Bottle?
ATM, I got some work to get done,
so the Bottle has to wait till I get some free time and a six-pack of motivator Fluid :wink:
Thanks for help everybody!!!
