Firs test... (interior)
Hasan
Post by Hasan » Wed Nov 28, 2007 2:00 am
Hi , its my first render. But I can not succeed in clear render. What time is needed?
Regards.
Hasan
SmartDen
Post by SmartDen » Wed Nov 28, 2007 2:11 am
what are you using as lightsource? if sunlight, then try to use exitportals in your windows.
dougal2
Post by dougal2 » Wed Nov 28, 2007 2:13 am
give it a day ;)
scenes usually start to look clean with upwards of 2000 - 3000 samples per pixel.
it varies a lot on the scene though, and will take longer than that to clear up some areas, especially where there are shadows or indirect lighting.
psor
Post by psor » Wed Nov 28, 2007 2:15 am
Hi Hasan,
first --> welcome aboard, have a seat - drinks are in the fridge!
Looks promising already. Some quick questions for ya.
1. How is your scene lit?
2. Did you use any exit portals?
3. Whats your system spec (CPU/RAM/OS)?
edit: Darn, I'm to slow! :P :D ;)
take care
psor
"The sleeper must awaken"
Hasan
Post by Hasan » Wed Nov 28, 2007 2:22 am
SmartDen wrote:what are you using as lightsource? if sunlight, then try to use exitportals in your windows.
SmartDen, not sunligt. I use blackbody spectrum.
   <background>
   <spectrum>
            <blackbody>
                <temperature>5000</temperature>
                <gain>1.0</gain>
            </blackbody>
   </spectrum>
   </background>
Hasan
Post by Hasan » Wed Nov 28, 2007 2:27 am
dougal2 wrote:give it a day ;)
dougal2, thanks for your explanations...
SmartDen
Post by SmartDen » Wed Nov 28, 2007 2:31 am
for better results you should use sun light + exit portals
Hasan
Post by Hasan » Wed Nov 28, 2007 2:37 am
psor wrote:Hi Hasan,
take care
psor
psor, thanks. I dont use exit portal. My system : 1 GB RAM, 1.7 GHz CPU :?
Kosmokrator
Post by Kosmokrator » Wed Nov 28, 2007 2:42 am
hhmmm u have problem with cpu power man......your scene will be need much time to clear even use exit portals.....
sug:buy new pc! :P
or have patience :P
SmartDen
Post by SmartDen » Wed Nov 28, 2007 3:00 am
Kosmokrator wrote:hhmmm u have problem with cpu power man......your scene will be need much time to clear even use exit portals.....
sug:buy new pc! :P
or have patience :P
not everybody can have such PC as you have ;)
Kosmokrator
Post by Kosmokrator » Wed Nov 28, 2007 3:05 am
im not talk about supercomputers......some simple core 2 duo 4500 or 6550 will do incredible work with renderings......and is in general terms cheap....anyway i dont say buy new pc with irony!.....just for him i know how it is to wait ages to finish the rendering ,i have too, some ages before ,slow pc :wink:
Hasan
Post by Hasan » Wed Nov 28, 2007 3:09 am
Kosmokrator thanks for the suggestion:)
I will try the exit portal...
Regards.
Hasan
Post by Whaat » Wed Nov 28, 2007 5:01 am
Looks like path tracing to me...maybe use MLT instead? Although using bidirectional path tracing with exit portals will work even better.
Hasan
Post by Hasan » Thu Nov 29, 2007 9:38 am
Whaat, yes, I just learn Indigo. Ok, I changed Metropolis =False and I use Exit Portal. Now, it is fast and clear. The render is running, but the result is following at 30. minute (800x600):
Post by Kram1032 » Thu Nov 29, 2007 10:23 am
Well, I'd say, Exit Portals where a good idea, but in this scene, I don't actually see too much direct light... SO, I bet, it's better to switch Metropolis on...
(you can easily see this, when looking at the carpet, which is noise-free, where the sun shines on it, but all the rest will stay relatively noisy...)
