Refraction 1.05
Refraction 1.05 and absorption
Refraction 1.05, absorption and subsurface scattering
Then I fixed the light setup, I found it was ok if there was burn since the light was very close.
About the same material as above
Then ok the mesh was OT so I did one from scratch, introducing a sphere generated by Indigo cut by a box filled with air.
Sun ans sky with turbidity=15
An almost-not-transparent material
There I told myself something was wrong, maybe the normals of the box... It is not smoothed normal wise
Then I imported the new scene into the former setup but messed up with the pixel ratio, and the connection was obviously too thick.
Er... some sort of rubber ?
So I started over with the "i" again, having a too large loop this time
Around 580 mut/pixel. Say it's stained glass
Everything rendered with Indigo 0.7t3, althought I didn't use a t3 specific feature here.
I hope you enjoyed the tour !
Cheers
440x440
