CoolColJ's test pics thread
joedizzle
Re: CoolColJ's test pics thread
Post by joedizzle » Sun Jul 01, 2012 4:31 am
Zom-B wrote:
CoolColJ wrote:real camera have way more diffraction at the same fstop as Indigo - me thinks the simulation needs tweaking :wink:
Maybe that (sadly still not released) Paper could be a good starting point:
Polynomial Optics: A Construction Kit for Efficient Ray-Tracing of Lens Systems
It's here, http://www.cs.ubc.ca/~hullin/#publications, interesting paper!
CoolColJ
Post by CoolColJ » Sat Jul 14, 2012 3:00 pm
Trying out an old exit portal test scene from Indigo v2 with v3.4.2
with an i7 970 - 6 core at 3.85ghz
Damn clean for only 4 mins and 363 samples :shock:
Ha - only 1 min, this new improved BPT is pretty fast... ahh memories of the old days with a Pentium 4 are no more...
Anyone with an x58 board, definitely pick up a second hand i7 970. Not much slower than a 3930k at the same clock speed, but it won't overclock as well. Runs much cooler than an i7 920 or 930 at the same clock speed!
dcm
Post by dcm » Sun Jul 15, 2012 8:31 pm
2600k ftw
CoolColJ
Post by CoolColJ » Sun Jul 15, 2012 9:42 pm
dcm wrote:2600k ftw
2 cores short of penile length :mrgreen:
Post by StompinTom » Mon Jul 16, 2012 9:52 am
CoolColJ wrote:
dcm wrote:2600k ftw
Baha!
Coming from a 980X over here...
FoXar
Post by FoXar » Mon Jul 16, 2012 10:47 pm
StompinTom wrote:
CoolColJ wrote:
dcm wrote:2600k ftw
Baha!
Oh don't "Baha!" too much, also have a 980X, clocked at 3.8GHz and watercooled..
Let's see who is "Baha-ing!" next :mrgreen:
Cheers,
Roo Evans
CoolColJ
Post by CoolColJ » Tue Aug 09, 2016 11:16 am
Trying to brute force this on my EVGA GTX 1070 FTW
and OpenCL path tracing - think I might resolve fairly well overnight :D
The underwater block seems to converge better than with MLT though
Post by Oscar J » Tue Aug 09, 2016 11:32 am
Oh man, classic thread. :) This is a gruesome task for single dir PT.
Post by lycium » Tue Aug 09, 2016 12:20 pm
I'm so glad to see this classic thread again, after 4 long years :D
Post by pixie » Wed Aug 10, 2016 4:28 am
Epic thread is epic! :D
CoolColJ
Post by CoolColJ » Fri Mar 25, 2022 3:14 am
So I have a Ryzen 5950x system now.... it's quite a bit faster than my previous Intel 3930k system :lol:
Also MSI RTX 3070 Trio
I decided try this classic scene out again, and the underwater bits were a bit slow to resolve, with a low sun angle, using the captured simulation, but started to show up after 10000 samples per pixels.
Now after 9 hours, at 6+ million samples per sec and 700k samples per pixel, it's actually fairly resolved :shock: :D
edit - I get 7 Million samples per sec with latest release candidate on the same scene
I also found setting the max path depth to higher numbers to be helpful, like over 32. I used 99
Especially in scene with high reflection and refraction. The caustics develop better and faster
Post by Headroom » Fri Mar 25, 2022 4:46 am
LOL, yes not a surprise. What render mode did you use for that image ?
The mention of max path depth indicates GPU use. But I would have imagined that the bidirectional path tracing, perhaps even with MLT converge much faster than brute force path tracing on the GPU.
I've got a number of renders where GPU rendering appears to be almost helpless. I can share those but don't want to spoil your thread with my images.
CoolColJ
Post by CoolColJ » Fri Mar 25, 2022 6:21 am
Headroom wrote: ↑
Bidrectional MLT on CPU... so the max path depth has no effect on CPU then?
It's much worse on GPU :)
Feel free to post in this thread
CoolColJ
Post by CoolColJ » Fri Mar 25, 2022 8:26 am
I have rendered this one before, but I always lost patience with it as it takes ages to converge.
Now with a faster CPU I redid it, and it took till 15k samples/pixel before the details started to show more on the red cyclinder, and +30K till more details showed up.
At 75+k S/P after 88 mins of rendering I think it's close to full converged :)
CoolColJ
Post by CoolColJ » Fri Mar 25, 2022 10:15 pm
ran this one for over 10 hours, restarted a few times, and the underwater block did eventually converge at 400k samples/pixel. I think another 5 hours will make it smoother.
So in 5 years time when CPUs are 10x faster, this will be no big deal, relatively speaking :)
