Another well-inspired work by Yonosoy.yonosoy wrote:A version of "One and Three Chairs". It is "One and Three Wineglass".
A natural situation...
- arc en ciel
Re: A natural situation...
Thank you a lot!
An experiment with custom atmopheres.
Cool stuff, will you enter the competition?
Thanks Ono.
Experimenting with bubbles inside water.
Seems that caustic process is not reflected in the bubbles walls.
Metropolis bidirectional. Overnight rendering.
The problem for this scene is the Sun & Sky system (the sun).
With a HDR map lighting the scene.
Bidirectional metropolis + Exit Portal. Indigo´s linear output with color curves correction.
- arc en ciel
wonderful
did you use realflow for bubble's mesh ?
Hi arc in ciel! Thank you.
Simple metaball question in Cinema4d.
Want to play with realflow more over...
This experiment is odd. Oddest in v4.
Capture simulation with eight exit portals.
Volume of gas 100x100x15 meters.
Good to see noise stucture!
- disection_of_a_volume.pigs
- (4.17 KiB) Downloaded 328 times
Hi.
A very simple simulation of the movement of the Troncotron over a surface.
Rendered with GPU in about 5-6 hours.
https://vimeo.com/223739756
Smoke.
Actually it has an espheric envelope. The volume has 5x5x2 kilometers...
Try to put this in order to share more over.
- Originalplan®
Quick and dirty mie_cumulus experiment.
With a LUT in post-pro.
- Polinalkrimizei
Awesome!!
One of the foggiest renders I've seen!
Thank you!! Yes, is half a cloud...
Is a bidirectional metropolis with a mie_cumulus volume experiment.
The bands green-violet are there again.
Overnight rendering (12h).
- Originalplan®
Once again very cool work/concept Yonosoy
