Architectural Visualization Study - The Farnsworth House
Jeff
Re: Architectural Visualization Study - The Farnsworth House
Post by Jeff » Fri Jun 04, 2010 6:24 pm
I re-rendered another scene. This time, I made the trees much bigger and closer to the house. Before they are really very far from the house. The location of the vegetation is now similar to the reference images.
Post by Pibuz » Fri Jun 04, 2010 10:53 pm
This is even better Jeff. Vegetation is now really good (I think because we can't see any too close :wink: )
I really like the greenish-blueish tone of Farnsworth 19H. I think you have to work a little on the marble floor mat now: at the moment it is somehow dull and too homogeneous, in my opinion.
studiouno
Post by studiouno » Fri Jun 04, 2010 11:00 pm
Jeff,
Very good render, i tried to render this house (see my joined picture). Is it possible to share your file?
I could give you some interesting file.
Studiouno,
Jeff
Post by Jeff » Sun Jun 06, 2010 5:03 pm
Pibuz wrote:This is even better Jeff. Vegetation is now really good (I think because we can't see any too close :wink: )
Thank you very much Pibuz. For the marble floor, I am still using the original material on the model and assigned the dull plastic preset on it. It looks like I need to add some bump into it.
Jeff
Post by Jeff » Sun Jun 06, 2010 5:13 pm
studiouno wrote:Jeff,
Studiouno,
Thanks Studiouno! Nice rendering you got there. I attached the sketchup file of the environment I am using. In order to reduce the file size, the house model was taken out. Since you have the model already, you can just paste it. After opening the file, you can see in the middle an outline where the house should be.
Cheers!
farnsworth environment.zip
(1.64 MiB) Downloaded 339 times
Jeff
Post by Jeff » Sun Jun 06, 2010 5:38 pm
With the trees, much closer to the house, I re-rendered a previous scene.
Post by OnoSendai » Sun Jun 06, 2010 6:45 pm
Oooh.. the last series of renders is lovely!
studiouno
Post by studiouno » Mon Jun 07, 2010 8:27 am
Thanks a lot Jeff, When I will make my test render, i will send you the results.
If you want some object, you could tell me.
Studiouno,
Jeff
Post by Jeff » Mon Jun 07, 2010 3:28 pm
OnoSendai wrote:Oooh.. the last series of renders is lovely!
Thank you very much OnoSendai!
Jeff
Post by Jeff » Mon Jun 07, 2010 3:36 pm
studiouno wrote:Thanks a lot Jeff, When I will make my test render, i will send you the results.
Studiouno,
You're welcome! You can post them here or you can also start your own WIP thread so we can discuss what needs to be done. That file I shared is the latest one. Images showing that new environment are still being rendered. The scenes I'll be posting shortly are still using the previous environment.
Jeff
Post by Jeff » Mon Jun 07, 2010 3:50 pm
Another batch of re-rendered scenes. I did try to add some bump on the floor but it seems that the value of 0.0001 is to small and there is no noticeable change. C&C's are welcome.
Post by StompinTom » Mon Jun 07, 2010 4:01 pm
21g is looking sick! Very lifelike.
Jeff
Post by Jeff » Mon Jun 07, 2010 4:21 pm
Thanks a lot Tom. For that image, I used the dscs315_1 camera response preset.
Camox
Post by Camox » Tue Jun 08, 2010 1:49 am
Awesome new stuff here ! great work. :D
studiouno
Post by studiouno » Thu Jun 10, 2010 7:30 am
Hello Jeff,
A lot of thanks about the environnement. It's amazing. How do you do to make instancing with grass and trees.
When I will have some samples, i will send you.
Sorry for my english, i am french.
Studiouno,
Users browsing this forum: Baidu [Spider] and 137 guests
