Architectural Visualization Study - The Farnsworth House
I would like to start a WIP on how to make very nice architectural visualizations. There are a couple of works I had seen here and on other forums that are very hard to distinguish from actual photos. This is the goal I would like to accomplish.
For the architectural model, I chose the Farnsworth house because there are a lot of very nice renders of it and photographs to compare with. The model of the house I am using was made by Peter Guthrie and it can be downloaded from his blog. My heartfelt thanks to him for sharing such a wonderful detailed model. He made a number of very realistic visualizations using the same model.
These are some of the links to renderings and photos of the Fansworth house. These would be used as references.
http://www.pushpullbar.com/forums/showt ... orth-House
http://www.mentalimages.com/gallery/architecture.html
http://www.flickr.com/photos/pg/sets/72157622626579436/
http://www.flickr.com/photos/suttonhoo22/tags/mies/
Some initial renderings, I prepared.
Re: Architectural Visualization Study - The Fansworth House
Some of the test renders here were done more than a week ago. At first, I was not planning to do a WIP thread and only thought about it lately.
Some more initial renderings.
6c and 5g look great! I would work on the grass and leaf materials now: add some low, rough specularity and possibly some translucency, it's too diffuse and unnatural right now.
The last one, 5g, is by far the most fantastic ! Wow
Looks nice, but plants a bit flat as mentioned
I also find the vignetting pretty excessive and distracting. Makes the pics look claustrophobic
Like a really old beat up camera
I hope one day Indigo will have an on/off switch for vignetting...
what kind of software you use? The trees and the grass is really good !!! Can you send me some?
Thanks a lot Tom! I'm working on that now. The grass and leaves materials have some translucency but it's not yet enough and it is not even noticeable.StompinTom wrote:6c and 5g look great! I would work on the grass and leaf materials now: add some low, rough specularity and possibly some translucency, it's too diffuse and unnatural right now.
Thanks a lot Stur! That image was also my personal favorite.Stur wrote:The last one, 5g, is by far the most fantastic ! Wow
Thanks a lot CoolColJ! For the vignetting, I still do not know how to control it .CoolColJ wrote:Looks nice, but plants a bit flat as mentioned
Forgot to mention this. I'm using sketchup. The tree on the scene is a modified version of this model: http://sketchup.google.com/3dwarehouse/ ... revstart=0 . The grass is made up of scattered curved slender triangular planes. The grass and trees are repeated on the scene using instancing. Information on it can be found here http://forums.sketchucation.com/viewtop ... 286c0ee57dPowerMax wrote:what kind of software you use? The trees and the grass is really good !!! Can you send me some?
Some more exterior and interior test renders done during the past week. C&C's are very welcome.
Setting a smaller camera aperature value does seem to help reduce the effect. It's not too bad at f5.6 compared to f16Jeff wrote:
The Fantasy.
How much on time occupies the visualization.
- zeitmeister
Wonderful!
Could you tell us something about your grass; are they instances? And which material did you use for it?
Thank you very much, very inspiring work!
Thank you very much!ENSLAVER wrote:Awesome.
Thanks a lot for the info CoolColJ!CoolColJ wrote:Setting a smaller camera aperature value does seem to help reduce the effect. It's not too bad at f5.6 compared to f16Jeff wrote:
Most of the renders are at 4000 samples/pixel and render times average from 8 hrs. to 15 hrs.on an intel core2quad 2.3 Ghz.Prof4D wrote:The Fantasy.
Users browsing this forum: No registered users and 180 guests
