psor
by psor » Mon Nov 20, 2006 4:55 am
BZ Win wrote:I also have no idea if this can be done in blender :p
*fg* Then u could try ... Menu: Object -> Clear/Apply -> Clear...
Dunno if it's right, I'm not yet a blender user. ;o))
take care
psor
"The sleeper must awaken"
zuegs
by zuegs » Mon Nov 20, 2006 5:25 am
yes, as psor says, try appling object transformation, because it you have unequal scaling for X, Y, Z on the object, the normals could be wrong.
me1
by me1 » Mon Nov 20, 2006 9:17 am
Win: Sometimes the normal recalculator gets stuff wrong and flips half the normals the wrong way. did you do CTRL-N or did you do it manualy?
This is my signature. Fear it.
BZ Win
by BZ Win » Mon Nov 20, 2006 9:20 am
Ctrl + N :-p
<----- is lazy
by StompinTom » Mon Nov 20, 2006 12:41 pm
check for any inside or overlapping faces. inside faces play hell with normals and sometimes are overlooked. then check for any missing faces anywhere on the mesh, then recalculate normals. post the .blend file of just the model if you want me to take a look.
Petr04
by Petr04 » Sun Nov 26, 2006 3:38 am
BZ Win
1251% - this is normal's!!!!!!!!!!
With glass is's looks very good.
If one normal outward and next negative then You will have as shown above.
Check "Your" normals :0).
SfmbE - Sorry for my bad English.
I hope, You understand me.
P.S.: SfmbE! I'm Russian!
BZ Win
by BZ Win » Sat Dec 02, 2006 6:39 am
It's odd... This doesn't occur in Blender internal, or Yafray, just Indigo :\
DaveC
by DaveC » Sat Dec 02, 2006 7:34 am
OK. I'm assuming that your sofa/couch/settee is a subsurfaced model. If I'm right, you need to apply the subsurfacing before you export the .xml. If I'm wrong then I'll just shut up
And, believe me, I could be wrong. Good luck.
BZ Win
by BZ Win » Sat Dec 02, 2006 7:49 am
Yeah, your wrong :-p
DaveC
by DaveC » Sat Dec 02, 2006 8:00 am
I'll just shut up, then
by CTZn » Sat Dec 02, 2006 9:07 am
Maybe you could share just a cushion so we can check geometries using various apps ? obj prefered, 3ds is ok too.
Users browsing this forum: DotBot [Bot] and 46 guests
