Syringes
Syringes
Post by neo0. » Mon Jun 09, 2008 11:23 am
The glass looks a little too prism like.
I used the glass preset (specular material.) I wasn't sure what to put for the scattering coefficient or the cauchy b.
kwistenbiebel
Post by kwistenbiebel » Mon Jun 09, 2008 11:38 am
Good start, but I don't see the connection between the medical and the wiimote....
Post by neo0. » Mon Jun 09, 2008 12:12 pm
For some people, Wii is like a drug craze.
What should I put for the cauchy b and the coefficient?
kwistenbiebel
Post by kwistenbiebel » Mon Jun 09, 2008 1:17 pm
Well, I think people won't automatically make the connection between the syringes and drugs in this image, unless something more of a clue is given.
Can't help you with cauchy b and coefficient, sorry.
The trick will be getting the 'precedence' for both media (glass and fluid) correctly.
Maybe the material experts on this forum can be of assistance...
Post by neo0. » Mon Jun 09, 2008 2:22 pm
Yep, I set the precedence for the glass to be higher than the fluid.
mr_jo
Post by mr_jo » Mon Jun 09, 2008 8:51 pm
neo0. wrote:Yep, I set the precedence for the glass to be higher than the fluid.
Hi neo, maybe the fluid should have precedence higher than the glass
Post by PureSpider » Mon Jun 09, 2008 11:20 pm
No, the glass precedence higher than the fluids is just fine, just use a b_coeff of 0 for the glass as the coefficient marks the dispersion (prism effect) of the glass
mr_jo
Post by mr_jo » Mon Jun 09, 2008 11:30 pm
PureSpider wrote:No, the glass precedence higher than the fluids is just fine
sorry guys, I've problems with my bad english :oops:
zsouthboy wrote:Precedence allows you to model volumes without having to hack them up to put them inside one another.
For example, you can enclose your scene with a SSS air volume for a fog effect, and give it a precedence of 1.
If you have another volume (say a cup of water) in your scene inside the air, you just choose a higher precedence for it to "displace" the lower precedence volume, so 2 or higher.
and put a piece of SSS plastic in that water -> precedence of 3 or higher.
The SSS plastic will automatically displace the fog and the water, and the water will automatically displace the fog.
http://www.indigorenderer.com/joomla/fo ... php?t=4272
Post by Kram1032 » Tue Jun 10, 2008 2:41 am
mr_jo, the glass still has to have higher precedence than the fluid ;) (except neo0. modelled the syringes as if they are solid glass cylinders and added a fludicylinder, to get the hole...)
How ever it might be, precedence looks right, here.
I only never saw a glass syringe - they usually are made of plastic with close to no chromatic dispersion....
mr_jo
Post by mr_jo » Tue Jun 10, 2008 3:05 am
Kram1032 wrote:mr_jo, the glass still has to have higher precedence than the fluid ;)
thanks Kram I'm sorry for my misunderstood :oops: :oops:
P.S. I have a doubt :?:
example: if I have a glass with prec=1 and a fluid whit prec=2 this for me means that the fluid has higher precedence (2 major than 1), is correct? or the minor number (1) means higher precedence?
Sorry again
mr_jo
Post by mr_jo » Tue Jun 10, 2008 3:09 am
Kram1032 wrote: I only never saw a glass syringe
ooohhhh I remember it very well :shock: :shock: :shock: when I was child the syringer was made of glass and let it boiled in a can before the sting, and I was terrorized of them :D :D :D :D
zsouthboy
Post by zsouthboy » Tue Jun 10, 2008 3:10 am
The precedence number should be interpreted literally.
Precedence of 2 is higher than 1, therefore material with precedence 2 will "displace" material with precedence 1.
mr_jo
Post by mr_jo » Tue Jun 10, 2008 3:26 am
zsouthboy wrote:The precedence number should be interpreted literally.
ok thank you zsouthboy;
so I'm a little confused with precedence (or the fault is of my bad english :oops: ); did you see my render of "pinocchio"? well if the precedence of my water is 10 and I decide to put a bottle of glass underwater, wich precedence should I assign to the glass?
zsouthboy
Post by zsouthboy » Tue Jun 10, 2008 3:39 am
Glass needs to be 11 in that case.
Make sure you model the thickness (but I think you understand that already) :)
EDIT: And your english is fine - I think you're having a tougher time understanding us than we are of you. :D
mr_jo
Post by mr_jo » Tue Jun 10, 2008 3:50 am
zsouthboy wrote:Glass needs to be 11 in that case.
ok, I'm in, thanks zsouthboy
zsouthboy wrote:Make sure you model the thickness (but I think you understand that already) :)
yes, yes is the first thing I've learned :)
zsouthboy wrote:EDIT: And your english is fine - I think you're having a tougher time understanding us than we are of you. :D
:D :D :D
