displacement tests thread
Post by OnoSendai » Wed May 28, 2008 3:08 pm
I think the problem is that the curvature of the triangles was zero. but so was the threshold, so the tris weren't being subdivided.
I guess i should make the test
split if curvature >= threshold
instead of
split if curvature > threshold
manitwo
Post by manitwo » Wed May 28, 2008 5:05 pm
stunning pictures guys :shock:
pxl666
Post by pxl666 » Wed May 28, 2008 7:11 pm
guys - can anybody pls answer my previous question? > "is this similar to use of disp mod in blender (BW disp map + hi poly mesh)? is this more memorywise than blender-like technique?" and could u post ur disp maps along with renders? and what is approximate polycount of this subdivided sphere?
cheers
drBouvierLeduc
Post by drBouvierLeduc » Wed May 28, 2008 8:27 pm
@pxl666 : Well, I'm not expert, but I think the result should be more or less the same. The only difference is that indigo performs some adaptative subdivision, meaning the mesh is only subdivided where it's needed--> smaller mesh (though the same kind of modifier for blender is in development).
In the end, I bet it will be much more practical to use indigo's displacement rather then applying tons of modifiers in blender.
The spheres I rendered have approx. 35000 faces, and are subdivided 3 times.
Post by BbB » Wed May 28, 2008 9:41 pm
Ono, are you thinking of adding a water-level feature? It basically cuts every parts of the mesh that are under a specified level of displacement. Very handy for wicker and other types of material with holes in it.
Post by OnoSendai » Thu May 29, 2008 12:04 am
Hi BbB,
Adding a water level feature doesn't look too hard, I'll give it a go.
Post by BbB » Thu May 29, 2008 12:24 am
Great to hear Ono!
Here's a belated attempt at grass. The sphere rendered for 20 min, the "landscape" for about twice as long.
Post by BbB » Thu May 29, 2008 1:15 am
Some kind of ivy thing
drBouvierLeduc
Post by drBouvierLeduc » Thu May 29, 2008 1:51 am
Ooh, me like that ivy. Would you share your displacement and color map ?
Post by BbB » Thu May 29, 2008 1:56 am
Nothing fancy, Dr Bouvier.
I just grabbed the diffuse map from CGtextures and used a greyscale version for displacement. It's not even tileable. But there you go, with some work maybe you could do something useful with it:
Adding an Arroway texture attempt. Now we can render these beautiful stone walls!
EDIT: Oops, sorry about the huge images. Here they are properly packed.
ivy.zip
(3.83 MiB) Downloaded 358 times
Gengibre
Post by Gengibre » Thu May 29, 2008 2:17 am
Wow, great test, awesome job OnoSendai... Iwill give it a try on the weekend...
mrmoose
Post by mrmoose » Thu May 29, 2008 3:30 am
Stone for me too! :wink:
matsta
Post by matsta » Thu May 29, 2008 3:57 am
hey guys
i tried some displacement a while ago, harrasing some dudes on chatzilla for help. still, my results were... crap. i was wondering if anyone could write a tut on displacement in blender and blendigo. if you cant be bothered then i spose dont worry, but i think it would be great for the wiki.
great work guys
greetz
mat
cpfresh
Post by cpfresh » Thu May 29, 2008 4:09 am
mrmoose
grab the official indigo preview scene. that scene you're using now (it looks like the one I 'doctored up' for sketchy) has some issues on and around the logo area -- looks strange. the latest one works much better! :D
drBouvierLeduc
Post by drBouvierLeduc » Thu May 29, 2008 4:35 am
@matsa : displacement doesn't work in blendigo (yet), it's one of the kick-ass hot feature of the latest indigo build. So you have to edit your file manually.
you have to edit two things :
* first, choose the mesh you want to displace, and add this code just before the <embeded> tag :
      	<normal_smoothing>false</normal_smoothing>
      	<max_num_subdivisions>3</max_num_subdivisions>
      	<subdivide_pixel_threshold>0.0</subdivide_pixel_threshold>
      	<subdivide_curvature_threshold>0.1</subdivide_curvature_threshold>
      	<subdivision_smoothing>true</subdivision_smoothing>
* then find the material used by the mesh, and add this code, somewhere between the <phong> or <diffuse> tag (change texture.jpg with your own texture) :
			<displacement_map>
          		  <uv_set>uv</uv_set>
            		<path>texture.jpg</path>
           		 <exponent>2.2</exponent>
           		 <b>0.035</b>
         </displacement_map>
Users browsing this forum: No registered users and 46 guests
