synthetic photography
yonosoy
Re: synthetic photography
Post by yonosoy » Mon Sep 11, 2023 3:28 am
The control of the diaphragm is in "diafragma blade", coordinates, rotation.
Now I´m investigating some things. For example, the film must to be in a fix position (it depends on the camera model) and till now I was playing with the position in order to focus...
So, once the film position is determined, you must try to obtained the IOR pair of crown and flint materials.
Synthetic photography is a "hard play", a beautiful investigation. It has no profesional exit I guess. But maybe for companys like nikon, canon etc. it has some kind of value to evaluate a possible objective before to construct it.
yonosoy
Post by yonosoy » Mon Sep 11, 2023 3:31 am
The dimensions of the objective must be precisse to determine the film position and till now this is no a guaranted.
Post by pixie » Mon Sep 11, 2023 9:22 pm
Indeed!
yonosoy
Post by yonosoy » Wed Sep 13, 2023 8:02 am
I will try, thanks...
Exteriors are faster...
yonosoy
Post by yonosoy » Wed Sep 13, 2023 8:23 am
large mutation probability 0.72, max change 0.13.
4K.
21 hours, 5800 spp.
20 minutes, 84 spp.
yonosoy
Post by yonosoy » Wed Sep 13, 2023 8:26 am
I introduce a divide node (to triangulate the meshes) and normals in houdini.
I think that is a better choice that a phong tag of cinema.
yonosoy
Post by yonosoy » Wed Sep 13, 2023 8:37 am
I´m most interested in the 20 minutes image.
yonosoy
Post by yonosoy » Thu Sep 14, 2023 9:00 am
yonosoy
Post by yonosoy » Wed Sep 27, 2023 3:56 am
Exteriors (with ambient) are a little more faster than interiors (only a little more speedy).
This one goes very noisy. 24 h of rendering.
Vignetting appreciable with the sigma 56 mm objective with double diaphragm.
The noise comes from a defect in the model. Solved.
yonosoy
Post by yonosoy » Thu Sep 28, 2023 12:56 am
What you give up if you decide to take synthetic photography...
Path tracing, GPU, clamp contribution, denoise, Open GL preview, etc...
Everything about the GUI that has to do with the camera, pick object, assign material, etc...
Render chanels, etc...
View dependent subdivision, etc...
The ortographic camera is facing the white film.
The camera must be in the 0,0,0 position.
Some day, photo-quimic events will be possible...
yonosoy
Post by yonosoy » Wed Oct 11, 2023 10:57 pm
Working. Will see if I can do something with this sketch...
1:25.
Sigma 56 mm, 8K.
HDR.
Post by pixie » Thu Oct 12, 2023 1:25 am
yonosoy
Post by yonosoy » Thu Oct 12, 2023 9:16 pm
Thanks for understand...
Yes, begins to be a scene...
yonosoy
Post by yonosoy » Sat Oct 14, 2023 11:04 am
I´m tryng to represent mold in the lenses, seems like an obstacle. Will see with time how obstacles works with lens systems.
Trying bumps, normals, etc. Hope are with displacements, though. But coatings has nanomilimeters and it is very difficult.
yonosoy
Post by yonosoy » Wed Nov 08, 2023 2:55 pm
Canon 24 mm.
F-stop 22 (minimum aperture for the objective).
25,1 x 25.1 milimeters.
Users browsing this forum: No registered users and 193 guests
