Tea party (final)
Tea party (final)
Post by BbB » Wed Dec 05, 2007 8:26 pm
Hi Guys. I was playing with materials yday and came up with this. The teapot and cups were both modeled in Blender. I've got some UV mapping problem on the teapot which I'm trying to fix. Strangely enough, the vertical line does not show in the Blender viewport. Only in Indigo.
Olis
Post by Olis » Wed Dec 05, 2007 9:14 pm
Wonderful models, fantastic stone texture. Are the models bumpmapped to look uneven or are they modeled that way? Looks fantastic anyway.
Post by BbB » Wed Dec 05, 2007 10:07 pm
Olis
Hi, thanks. Yes, there is a procedural cloud bump map on the models to give them a slight handmade feel. That's also why I'm getting this annoying UV mapping problem on the teapot. Glad you like it.
Marcofly
Post by Marcofly » Thu Dec 06, 2007 12:04 am
wonderful material!
it can be used as a leather mat!! Think about it!
ciao!
Post by OnoSendai » Thu Dec 06, 2007 12:22 am
Hi BbB,
which Indigo version did u use?
Post by BbB » Thu Dec 06, 2007 12:31 am
Hi Ono.
This was 1.0.3.
Why do you ask?
EDIT: If it's about the UV mapping problem, I think I found what caused it. The teapot has one level of subdivision, but I didn't apply the modifier in Blender. Sometimes, this screws up the UVs slightly. I'm now rendering a version with the modifier applied and it seems better, though it's hard to tell for sure before the image has converged.
Post by OnoSendai » Thu Dec 06, 2007 12:33 am
Because I changed the texture tiling code a little in v1.0.4. Perhaps it will fix your seam.
Post by BbB » Thu Dec 06, 2007 12:35 am
I'll try 1.0.4 then. Cheers.
EDIT: This is not a tiling texture but a baked procedural, custom-made for each object. Really I think the problem is more with Blender (or even possibly with me :wink:
SmartDen
Post by SmartDen » Thu Dec 06, 2007 12:55 am
Nice render, BbB, as usual. But i miss some scratches...
crojack
Post by crojack » Thu Dec 06, 2007 5:16 am
It does have a leather look to it, and the vertical line is the seam of the leather, :)
mzungu
Post by mzungu » Thu Dec 06, 2007 7:00 am
I must say that marble is just tremendous. Does it have sss applied? Is the bump map a tangent space normal map? It just looks too real, dood! Sweet!
-mzungu
"The fear of the Lord is the beginning of wisdom" - Solomon
Post by BbB » Thu Dec 06, 2007 7:09 am
mzungu
Hi there. The stone was a sheer stroke of luck. Believe it or not, it has no bump map and no SSS. Just the diffuse map plugged into the exponent channel and with the gamma raised to 3. I've been playing with the exponent slot lately and I'm amazed at how much you can do without bump. And it speeds the render too (I think).
CoolColJ
Post by CoolColJ » Thu Dec 06, 2007 9:14 am
that granite bench top looks convincing, we have one here, with the exact same pattern :)
Post by BbB » Thu Dec 06, 2007 8:19 pm
Hi guys. A few changes in this image. First of all, I wanted to see whether I could model a leather cushion in Blender without using the sculpt tool. The answer is: kind of, as long as the vertices are aligned with the direction the folds would take. So this requires a good reference image. Right now the pillow has massive UV mapping issues (my fault, not indigo's) which is why I'm only showing a close up (the sides of the cushion are the main problems).
I've also fixed the tiling issue on the teapot's bump map, only to see another "hole" appear at the top rim. This is definitely a Blender problem, which I'll have to fix before cooking the final image.
I've corrected the wrong scale in the first image, which among other things means my tea now renders as tea and no longer as coffee.
That pretty much sums it up
Pinko5
Post by Pinko5 » Thu Dec 06, 2007 9:56 pm
wow BbB very very very good work.......!!!
Luca.
