A diamond ring
15 posts • Page 1 of 1
contegufo
A diamond ring
Post by contegufo » Thu Jun 02, 2016 9:25 pm
Hi
A diamond ring as a gift!
Re: A diamond ring
Post by Oscar J » Thu Jun 02, 2016 10:23 pm
Re: A diamond ring
Post by pixie » Thu Jun 02, 2016 11:33 pm
Oscar J wrote:Looks awfully similar to this: http://www.indigorenderer.com/images/diamond-studio
You spoiler!! :P
contegufo
Re: A diamond ring
Post by contegufo » Thu Jun 02, 2016 11:38 pm
The 3D models databases are the same for everyone! :D
Re: A diamond ring
Post by pixie » Fri Jun 03, 2016 12:51 am
contegufo wrote:The 3D models databases are the same for everyone! :D
And what have you learn from this same model in another studio setup?
Originalplan®
Re: A diamond ring
Post by Originalplan® » Fri Jun 03, 2016 12:53 am
Lightning isn't good.
Try use a CAM setting with 100ISO and 100exp.
And dimm the lights too till white is white and not gray.
:wink:
contegufo
Re: A diamond ring
Post by contegufo » Fri Jun 03, 2016 3:51 am
My studio setup is not a secret. Alternately a semicircular crown emissive a toroid, sometimes one or two light area. Gemstones are particularly difficult materials. I try to do something personal; I think I'm on the right track!
All images have been processed with Photoshop.
Re: A diamond ring
Post by pixie » Fri Jun 03, 2016 7:28 am
contegufo wrote:My studio setup is not a secret. Alternately a semicircular crown emissive a toroid, sometimes one or two light area. Gemstones are particularly difficult materials. I try to do something personal; I think I'm on the right track!
Let me rephrase it then, from those two setups which is better and why?
Re: A diamond ring
Post by Zom-B » Fri Jun 03, 2016 7:05 pm
Your image is ultra dark, is there any reason for that?
contegufo
Re: A diamond ring
Post by contegufo » Fri Jun 03, 2016 7:22 pm
Hi
This it would be the same as I worked on the levels.
contegufo
Re: A diamond ring
Post by contegufo » Fri Jun 03, 2016 7:38 pm
Another version. the background a bit 'dark wanted to accentuate the contrast between the ring and set where it is placed.
contegufo
Re: A diamond ring
Post by contegufo » Sat Jun 04, 2016 8:30 pm
Hi
The latest versions with two light area and slightly correct levels in Photoshop.
The end result looks decent as regards the gems.
Re: A diamond ring
Post by pixie » Sat Jun 04, 2016 10:35 pm
contegufo wrote:Another version. the background a bit 'dark wanted to accentuate the contrast between the ring and set where it is placed.
If you wanna check how much contrast one image really have you ought to turn it into black and white, as from you can see there's not much contrast between the ring and the background, either step way up or way down.
contegufo
Re: A diamond ring
Post by contegufo » Sat Jun 04, 2016 11:23 pm
Generally when photographing a gold object with gems using a ring light and dark background as blacks fabrics, velvet and so on.
In some pictures in the gallery Indigo I saw that the backgrounds are blacks.
At this time I started the rendering background with black / graphite.
We wait for the result!
contegufo
Re: A diamond ring
Post by contegufo » Sun Jun 05, 2016 7:30 pm
Hi
Here is the version with black / graphite. The contrast is strong too.
Users browsing this forum: Majestic-12 [Bot] and 135 guests
