LEGO render
LEGO render
Hi
The pins are of brick faceted you can have them smooth?
In C4D function Mesh / Subdivide not results. In SketchUp I do not know.
Rendering in SketchUp.
Re: LEGO render
They simply need more segments.
Re: LEGO render
Hi contegufo,
in german the function is called -Kanten abmildern-, select the mesh(edges+faces) you wand to smooth->right click-> smooth edges, or something like that.
Re: LEGO render
Hi contegufo.
Try to add a phong tag, seems that the mesh has not one.
Re: LEGO render
Hi
After you apply the tag to all objects Phong OpenGL preview is correct and also rendering in Indigo.
However, enlarging the area you can still see the faces.
- pixie
Re: LEGO render
It doesn't do magic, it works with what it have. The phong is applied you have to make a cylinder with more faces.contegufo wrote:Hi
Re: LEGO render
In SketchUp, when you first draw the circle before using the Push/Pull Tool, select the circle, right click, Entity Info then change the number of segments to a higher number, for example 96 rather than the default of 24.
Re: LEGO render
Hi
Unfortunately there are too many to be redone, and it makes no sense. I will not make enlargements but only shots That do not see the facets.
Or I will cover the bricks so everything remains hidden.
The bricks are imported from LeoCAD.
- pixie
Re: LEGO render
You migh light to try this plugin
http://lesterbanks.com/2014/02/cinema-4 ... ego-brick/
Re: LEGO render
Hi pixie
Thanks, Brick gen plugin cost €9.
It seems very versatile and solves the problem by increasing the number of the faces.
- pixie
Re: LEGO render
This was not the lego Plugin I was looking for, sorry! xDcontegufo wrote:Hi pixie
https://cgtools.com/lego4d/
This is, and also free
Users browsing this forum: Majestic-12 [Bot] and 140 guests
