Post by Oscar J » Wed Jul 29, 2015 3:52 am
I like tricks. My experience is that in professional CGI production, you always end up using cheats and tricks anyway, so you might as well let Indigo do it for you. :)
thesquirell
Post by thesquirell » Wed Jul 29, 2015 7:54 am
True that! :D
Post by OnoSendai » Wed Jul 29, 2015 8:33 am
Oscar J wrote:I like tricks. My experience is that in professional CGI production, you always end up using cheats and tricks anyway, so you might as well let Indigo do it for you. :)
Exactly. The idea is to save the end user from having to shop in some clouds, or to prevent the end user having to use an env map. (that will probably result in an incorrect look due to non-physical values in the env map)
Zalevskiy
Post by Zalevskiy » Mon Aug 03, 2015 11:15 pm
real flow + cinema 4d + indigo simple test
Post by Oscar J » Tue Aug 04, 2015 2:10 am
Nice, though the fluid looks a bit low-res for some reason. Keep tweaking :)
Post by neo0. » Sun Aug 09, 2015 6:52 am
Perhaps not so simple but i wanted to share :D
Probably one of the most ambitious things ive done with indigo in awhile. Modelling took quite awhile and then the rendering took a few days of tweaking xD Some post pro done in ps cc
Post by neo0. » Tue Aug 18, 2015 1:25 pm
Cheers
Post by neo0. » Sun Aug 30, 2015 5:38 pm
Anyone down for some pie? :D
contegufo
Post by contegufo » Mon Aug 31, 2015 11:23 am
Do you like sweet whimsical?
raspberries and chocolate
Cream and chocolate
Orange and chocolate
Post by CTZn » Fri Sep 04, 2015 12:06 am
late answer...
thesquirell wrote:In general, I dislike tricks in CG, but sometimes we are forced to use them. Dreaming of day when we will have powerful machine that enables us to do whatever we want, and simulate everything in RT! :D
absolutely true I'm a playful idealist that's all :lol: Ono's trick is doing fantastic, and this quickly.
tarikb
Post by tarikb » Thu Sep 24, 2015 2:06 am
I used
Enviroment>Sun and Sky (turbidity 2)
Bidrectional with MLT
Focus point aperture f1.4 Aperture Diffraction
Any sugestions? Thnx
Skindigo
dcm
Post by dcm » Thu Sep 24, 2015 2:08 am
rendertime ?
tarikb
Post by tarikb » Thu Sep 24, 2015 2:13 am
Render time 15min (Samples per pixel 200 ) it's just test render whit a little of photoshop
Skindigo
Post by Pibuz » Thu Sep 24, 2015 2:13 am
Everything looks shiny, even the sectioned walls: I suggest you check you mats and set the white walls as diffuse and paint the back face with a flat black. This way, you'll enhance the perception of the inner architecture, which I think is the aim of the work.
IMHO work a little in postpro on the contrast to give more overall depth!
Post by Oscar J » Thu Sep 24, 2015 2:30 am
Try to tweak the colour balance until you get rid of that sterile, blueish tint of your whites. Will look ten times better. :)
