M-Pixel Render-Stuff
M-Pixel
Post by M-Pixel » Wed Jan 15, 2014 9:34 am
Hi All :P
i start a new Topic with all my Finals an render-tests.
Here my first Image. *no Post*
C&C are welcome!
galinette
Re: M-Pixel Render-Stuff
Post by galinette » Wed Jan 15, 2014 9:26 pm
Comments : very nice!
Just something that seems strange to me : the background behind the large tree seems not to fit with the mountain background on the left, as if there was an error and two different backplates were used for the two windows. I'm sure it's not the case, but visually it's hard to figure what's the house environment. Maybe there is a mismatch between the lightness of the mountain, the white part behind the tree, and the house interiour. Did you composite or use a backplate, or did you use a HDRI for both lighting and background?
Etienne
Eclat-Digital Research
http://www.eclat-digital.com
M-Pixel
Post by M-Pixel » Wed Jan 15, 2014 10:13 pm
HI
I am with you.
The BG Picture was blue on the right Side .
more sky and Sun Gain ovveride the Blue color.
kklors
Post by kklors » Thu Jan 16, 2014 1:41 am
Nice!
I think the light balance is ok the way it is. It might appear off also because the windows on the left have a strong tint or are a bit too thick?
My only complaint would be the needle tree in a southern (northern Italy?) environment, even if it's inside the house.
Is the Sun done separately? It looks nice.
fenerolina
Post by fenerolina » Thu Jan 16, 2014 6:59 am
Looks good!
My critic goes for the tree aswell: it looks like a young tree shape for me so it shouldn't be scalled so big. I think for a bigger/older tree, we should see more the trunk and the lower branches should be dead. Another detail is that it seems there's no diference between inside parquet and the tree space floor.
galinette
Post by galinette » Thu Jan 16, 2014 9:55 am
M-Pixel wrote:HI
I am with you.
Maybe using a darker concrete material for the outside wall would improve this, it is too overexposed. I did not notice there was a wall there until your modeler screenshot. You could also try changing the envmap orientation a bit?
The interiour is very nice!
Cheers
JK
Post by JK » Thu Jan 16, 2014 10:49 am
The thing I would try to improve is the floor - don't know maybe a better bump but it should use some exponent, at least a little! It just looks too flat to me. But I may be wrong. Anyone else noticed that?
Overall very good! Hope I could finish something like that in a couple of weeks. Damn!
Cheers,
M-Pixel
Post by M-Pixel » Thu Jan 16, 2014 3:05 pm
THX all for c&C
I'm going to make it bedder :)
Floor, Concrete BG and the Tree
First Test with alpha in PS
Change Tree an BG a little bit
galinette
Post by galinette » Thu Jan 16, 2014 6:57 pm
M-Pixel wrote:THX all for c&C
Much better! Just tune slightly down the concrete reflectivity now. Concrete usually has an albedo between 0.2 and 0.5
Also the wood flooring is very shiny, but that's more a matter of taste. I personally like old waxed wood, not glossy ones :)
M-Pixel
Post by M-Pixel » Sat Jan 18, 2014 9:35 am
HI ..
New updates :)
Floor, Wall, Tree Light and Carpet
6 Picture
Cheers
fenerolina
Post by fenerolina » Sat Jan 18, 2014 3:19 pm
That carpet looks awesome!
I personally prefer the first render (fin t1) as there are more contrasts. Generally more light sources = flat image.
About the floor, an exponent map wouldn't hurt: If you want to achieve a natural look, some boards should be more shiny than others. (hard/soft wood). If you want super coated wood it was ok in the first renders. As Etienne said, its a matter of taste.
That fir still looks odd to me, try to prune some branches or change it directly :) Do it carefully as it is in the center of the image.
M-Pixel
Post by M-Pixel » Thu Jun 26, 2014 1:23 am
Hi all,
here a new Render with Indigo.
C&C are welcome!
Bosseye
Post by Bosseye » Thu Jun 26, 2014 3:13 am
Nice mood!
Only thing for me is I want to see the view and there's a massive plant in the way.... :lol:
M-Pixel
Post by M-Pixel » Thu Jun 26, 2014 6:29 am
Yes but only on one Side ;)
DJ AntOn
Post by DJ AntOn » Tue Jul 22, 2014 5:47 pm
M-Pixel wrote:Hi all,
C&C are welcome!
very nice
