Violet version 0.1.2-rd now available
2 posts • Page 1 of 1
rerdavies
Post by rerdavies » Sat May 19, 2007 8:54 am
Win32 Installer:
http://www.ottawajazzcollective.com/dow ... 1.2-rd.zip
Source:
http://www.ottawajazzcollective.com/dow ... .2-src.zip
vs 2003 build coming shortly.
Changed in this version:
  • Linear contrast scales relative to 1.0.
    Multi-threading support for tonemapping operations.
    Default Noise Reduction is none.
    Fixed crashes when diffraction-limited bloom radius is small.
    "Indigo" in title bars changed to "Violet".
    Well. At least the icon is the right color. Needs more work.
    Histogram re-scaled for use Ansel Adam's ten zones system,
    rather than 17 stops of a full range image (gamma included).
    The 17 stop range indicates where detail falls relative to
    the blackpoint of the raw image; 10 zones seem to provide
    a better indication of whether there's actual detail in the
    black areas or not. Really an aesthetic decision more than
    anything else. How black is too black?
    Range-clip before downsampling, in order to improve Reinhard
    behaviour with over-value pixels. Compute the histogram at the
    same time to allow display of overvalues in the histogram.
    Don't recompute image when saving. (Disable of menus is good enough
    to ensure that there's a valid image).
    Tweaked range of stop-related sliders.
    Major performance improvement in Diffraction-limited bloom.
    #ifdef USE_OPENMP to eliminate errors non-OpenMP compatible systems.
    Progress on status-bar for long-running operations.
Todo:
  • Further research on the Wine loader issues.
manitwo
Post by manitwo » Sun May 20, 2007 3:12 am
perfect :shock: :D thank you!
