[ISL] Fresnel-Shader
9 posts • Page 1 of 1
Post by zeitmeister » Fri Nov 27, 2009 2:03 am
Hey,
I wondered where I can find information about coding a simple fresnel shader in ISL; from black (outwards) to white (inwards).
ISL documentation is few and confusing in my eyes... can someone please post a sample code like above?
I want to use this shader as a blend map/blend shader in Cindigo.
Maybe fused will have to give me further advice on that, but at first I would like to code this simple shader.
Can someone please help me?
Thank you very much in advance!
Re: [ISL] Fresnel-Shader
Post by CTZn » Fri Nov 27, 2009 7:51 am
According to the last Indigo technical manual version, the possible interactions of ISL with the scene are too limited, only texture sampling functions are allowing to query data from the scene.
For that shader you basically need two missing informations:
the camera direction:
  • it is already known at scene export time and present in the IGS, bringing it to the ISL engine is a possible task wich fused realised already iirc.
the direction of the normal of the sampled surface:
  • That one we can't access at all, if I am correct
Once ISL will allow to access these informations one would be able to do dust and snow shaders (not to mention a simple cell shading), because ISL is already providing the tools to manipulate vectors.
For now you can bake blend maps from your fav'app :)
If I have missed some ISL update please let me know, I'll be on your trail then zeitmeister !
Post by fused » Fri Nov 27, 2009 10:04 am
not possible currently because we cant acces the normal... :(
Post by CTZn » Fri Nov 27, 2009 10:43 am
mewants a snow displacer for christmas Image
Really a good approach to learn shading with ISL, nice pick zeitmeister.
Post by zeitmeister » Fri Nov 27, 2009 8:53 pm
Oh, this is a pity.
I can't believe that we can't get access of the normals direction towards the camera... other shaders work with that too, or am I wrong?
There was a post a while ago where in a phong-material "<fresnel_scale>0.1</fresnel_scale>" was being used.
So I thought this has been implemented, but maybe not referred?
Hm.
Then, I need the glossy transparent material redone... it should have the option to work either with RGB colors or with textures; because only that enables real SSS for textured materials.
Like skin textures, for example.
Post by fused » Sat Nov 28, 2009 2:01 am
zeitmeister wrote:Then, I need the glossy transparent material redone... it should have the option to work either with RGB colors or with textures; because only that enables real SSS for textured materials.
check out the absorption layer in cindigo 2.2.8 ;)
oh well... as soon as i get that mac build out!
Post by zeitmeister » Sat Nov 28, 2009 2:16 am
Post by fused » Sat Nov 28, 2009 9:30 pm
shaders based on normal direction may be possible very soon ;)
Post by CTZn » Sun Nov 29, 2009 12:45 am
Great !
This thread will revive then :)
