PLEASE HELP!!!!
Re: PLEASE HELP!!!!
Post by Borgleader » Sat Jul 18, 2009 2:02 pm
Wrong, I said look for the name inside the file, not the name of the file. If you look carefully you'll notice that inside the "Ghot_Glass.igm" file there is a "Thin Glass" material (of type blend) that is using two sub materials called "SP_Thin Glass_SP" (type phong) and "NULL_Thing Glass_NULL" (type null).
Of course you want the resulting material, which is the one of type blend, so you should name your blender material "Thin Glass".
Do you follow the logic?
3D Geek
Re: PLEASE HELP!!!!
Post by 3D Geek » Sat Jul 18, 2009 2:17 pm
Whenever i tried to get into the file ti wouldn't let me because it said it needed a program to run it.
Re: PLEASE HELP!!!!
Post by Borgleader » Sat Jul 18, 2009 2:18 pm
3D Geek wrote:Whenever i tried to get into the file ti wouldn't let me because it said it needed a program to run it.
Notepad will (I'm assuming you're working on windows).
EDIT: notepad will also read .igs files (the scene files upon export). I do however suggest notepad++ (google it) because the bigger the file gets the higher your chances of notepad crashing. For material files (.igm) its no problem but for scene files (.igs) it most likely will.
3D Geek
Re: PLEASE HELP!!!!
Post by 3D Geek » Sat Jul 18, 2009 2:22 pm
ooooooooooooh, ok thanks, now i see it! :)
Re: PLEASE HELP!!!!
Post by Borgleader » Sat Jul 18, 2009 2:25 pm
good :) good luck and happy blending!
3D Geek
Re: PLEASE HELP!!!!
Post by 3D Geek » Sun Jul 19, 2009 12:31 pm
OK, i know that this thread was supposed to be dead, but now im having another problem with a mterial from the database.Whenever i apply the frosted galss material from the database on to something, it turnd out like this. Whenever i try to make my own glass like materials it does the same. What am i doing wrong?
Re: PLEASE HELP!!!!
Post by PureSpider » Sun Jul 19, 2009 12:37 pm
You are doing the normals wrong. Reverse them.
3D Geek
Re: PLEASE HELP!!!!
Post by 3D Geek » Sun Jul 19, 2009 12:38 pm
well i tried flipping the normals and i got the same result
3D Geek
Re: PLEASE HELP!!!!
Post by 3D Geek » Sun Jul 19, 2009 1:49 pm
no solutions?
Re: PLEASE HELP!!!!
Post by Borgleader » Sun Jul 19, 2009 3:00 pm
Does it have thickness? If it doesnt its normal for it to go black.
3D Geek
Re: PLEASE HELP!!!!
Post by 3D Geek » Sun Jul 19, 2009 3:44 pm
o, ok thanks i will try that
3D Geek
Re: PLEASE HELP!!!!
Post by 3D Geek » Sun Jul 19, 2009 4:59 pm
ok i tried thickening up a modle and it did the same thing, but this time i used the emerald material from the database. Any other suggestions?
Godzilla
Re: PLEASE HELP!!!!
Post by Godzilla » Sun Jul 19, 2009 5:25 pm
How large is the model? can we see a screenshot from the viewport?
Re: PLEASE HELP!!!!
Post by PureSpider » Sun Jul 19, 2009 11:44 pm
Be sure all normals are pointing outwards after giving it some volume!
3D Geek
Re: PLEASE HELP!!!!
Post by 3D Geek » Mon Jul 20, 2009 4:15 am
ok well heres the scene, ther is a sphere behind the wall with the emerald material applied to it.
