Terrain shader
wlf_alex
Re: Terrain shader
Post by wlf_alex » Mon Dec 17, 2012 11:25 am
FakeShamus wrote:here's the blend version of the snow cover material: http://www.indigorenderer.com/materials/materials/1132
easy enough to replace the 2 materials I have in there now with your own ground/rock and some sort of green vegetation instead of the snow. this is very basic, though - I would live to see some real procedural terrain shaders built into Indigo, with easy to use parameters.
Yes, with textures this material gives a more realistic picture :
I hope the new shader from Ono add even more realism.
FakeShamus
Re: Terrain shader
Post by FakeShamus » Mon Dec 17, 2012 2:43 pm
Looks pretty good! Feels like it needs just a little bit more break up, in the form of some noise in the bump, maybe. But again, having a fully procedural fractal surface instead of a polygon mesh for the mountains would be best. Problem always seems to be, you can never get enough poly's to make the ground look detailed enough.
Re: Terrain shader
Post by CTZn » Mon Dec 17, 2012 6:24 pm
FakeShamus wrote:Looks pretty good! Feels like it needs just a little bit more break up, in the form of some noise in the bump, maybe.
Hi FakeShamus, it was easy to make your shader parametric with a "slope" factor.
Why not ?
Re: Terrain shader
Post by CTZn » Mon Dec 17, 2012 10:25 pm
I have slightly abused one of your textures in this shader:
Actually, apologies for the thread and texture highjacking combo.
terrain_terraces_textured.pigm
(1.23 MiB) Downloaded 295 times
wlf_alex
Re: Terrain shader
Post by wlf_alex » Mon Dec 17, 2012 11:21 pm
CTZn wrote:I have slightly abused one of your textures in this shader:
A very interesting result! But I can not use this shader to Cindigo!? :(
FakeShamus
Re: Terrain shader
Post by FakeShamus » Tue Dec 18, 2012 12:58 am
CTZn wrote:it was easy to make your shader parametric with a "slope" factor.
Why not ?
...cause I actually have no idea what I'm doing in ISL, I just copy and paste from better men than me for this stuff :wink:
If someone wants to redo the "snowy rock" and "mossy rock" with parametric controls and replace my versions that would be fine with me!
FakeShamus
Re: Terrain shader
Post by FakeShamus » Tue Dec 18, 2012 4:29 am
ok, yeah, it was easy to make the snow cover parametric - lower values = more coverage:
snowy_rock_par.pigm
(2.14 MiB) Downloaded 277 times
FakeShamus
Re: Terrain shader
Post by FakeShamus » Tue Dec 18, 2012 5:27 am
and here's a new "mossy rock" with sliders for direction and amount of coverage:
mossy_rock_par.pigm
(4.9 MiB) Downloaded 301 times
Re: Terrain shader
Post by CTZn » Tue Dec 18, 2012 7:12 am
Very nice shaders, I'm glad you made the move. It would be great to update your mats on the DB.
Alex, I can't tell about the extent of the ISL implementation in Cindigo, I'm not competent in the matter. I jumped on the ball when it came to ISL, sorry about that.
