Visiosun Classic glass / flutes glass
13 posts • Page 1 of 1
Dziadek-NET
Post by Dziadek-NET » Fri Mar 21, 2025 9:14 pm
Hello
I'm a hobbyist with this render, I use it in conjunction with SketchUp 2017
As in the subject, please provide instructions on how to make such glass.
Colorless, not completely transparent.
Smooth on one side, visible groove on the other (photos attached)
I really want this similar glass.
Best regards
Re: Visiosun Classic glass / flutes glass
Post by pixie » Fri Mar 21, 2025 9:55 pm
That sir.. that's how its done! Great work
burnin
Post by burnin » Mon Mar 24, 2025 2:36 am
@pixie
Those are photos, OP wants a tutorial ;)
@OP
Model the 'panel' and apply some from "Glass material library" for a starter
Dziadek-NET
Post by Dziadek-NET » Tue Mar 25, 2025 6:54 pm
I don't know much.
Can I ask for a tutorial, photos of what and where to put?
I would be very grateful!
burnin
Post by burnin » Wed Mar 26, 2025 6:11 pm
Sadly there's no specific 'Academy' like curriculum tutorial. So you'll have to do the studies yourself.
You'll find some within Resources/Tutorials and check those under Skindigo section. Also, help yourself by going through the Indigo Manual.
You could also ask, if any proficient Skindigo user here is willing to tutor you or at the very last, being commissioned.
Do well and have a good day.
Post by pixie » Fri Mar 28, 2025 11:31 pm
I started by doing displacement but ended modelling the glass. I did it in cinema 4d, but I can send you the model if you give me the dimensions you're planning to use
Post by pixie » Fri Mar 28, 2025 11:32 pm
@pixie
Sometimes I forget that real life also gives the same type of pictures as that of indigo xD
Post by pixie » Fri Mar 28, 2025 11:44 pm
bidir test
vs
path tracing on gpu diffuse depth 12
Dziadek-NET
Post by Dziadek-NET » Wed Apr 23, 2025 6:37 pm
Wow, great!
Did you do this in Cinema 4D? Is that a different program than Indigo?
Did you model this glass as a 3D model?
Aha... I thought you could get this effect using a texture?
For testing, I'd like a model measuring 817x2017mm and 8mm thick.
Post by pixie » Sun May 04, 2025 11:47 pm
Indigo is the renderer, I used Cinema4D for modelling. I tried texture, but modelling gave me not only a better result, but smaller memory usage in the end. Once I got the desired effect on 3D, one might create a displacement texture out of it.
glass_model.zip
(1.84 MiB) Downloaded 1455 times
Post by pixie » Mon May 05, 2025 7:35 pm
Updating the model to align more closely with the image reference.
Post by pixie » Mon May 05, 2025 8:20 pm
lol, I did the glass in the portrait mode, I will post here the correct version, I think xD
Landscape.zip
(794.58 KiB) Downloaded 1315 times
Post by pixie » Tue May 06, 2025 8:29 am
This time I baked the geometry into a normal map, what you see is just a normal map applied to a box. It might be all that you want.
Users browsing this forum: No registered users and 70 guests
