Hello,
Another of my problem why materials like liquids or sss render so dark with Bidr Path tracing method inside glass,These liquids inside glass or sss materials render so good with normal path tracing method. Here i am giving u a scene with glass and milk plus a tube light inside glass and milk and a studio light for environment set the (White light layer to somewhat 75.000) to get better environment light.
MilkTestscene:
Why Liquids render so dark inside glass with BidrPT
Googog Mogog
Re: Why Liquids render so dark inside glass with BidrPT
The precedence of the glass need to be at least 1 higher then the fluid!
Last page of Indigo Manual shows how to setup a fluid in Glass scene, check it out
SSS is scale related, take care to export your scene in life size scale.
A 10m high glass filed with red wine isn't transparent anymore
Googog Mogog
Welcome Zom-B i am going to try it thanks for your suggestionsZom-B wrote:The precedence of the glass need to be at least 1 higher then the fluid!
Googog Mogog
My 3Ds Max space is set to CM by default should i change it to inches for my glass?Googog Mogog wrote:Welcome Zom-B i am going to try it thanks for your suggestionsZom-B wrote:The precedence of the glass need to be at least 1 higher then the fluid!
Googog Mogog
Woo hoo dude!Zom-B wrote:The precedence of the glass need to be at least 1 higher then the fluid!
My milks glass worked with biderPt oh yeah thanks
You have to do the math by your own mate, if your glass is 100cm tall then downsize it or switch to mm.Googog Mogog wrote:My 3Ds Max space is set to CM by default should i change it to inches for my glass?
Googog Mogog
well thanks i did it alreadyZom-B wrote:You have to do the math by your own mate, if your glass is 100cm tall then downsize it or switch to mm.Googog Mogog wrote:My 3Ds Max space is set to CM by default should i change it to inches for my glass?
