HDRI as material ?
5 posts • Page 1 of 1
solarray
HDRI as material ?
Post by solarray » Mon Mar 14, 2011 3:00 am
Isn't it possible to give for example an simple mesh plane an hdri map as emitter ?
Re: HDRI as material ?
Post by Zom-B » Mon Mar 14, 2011 4:09 am
yes, it is possible :)
Simply load the map as a emitter texture.
Beware of the idea to load a HDRI latlong pano into a own sphere to have better control!
Indigo does some precalculation of HDRI's used as EnvMap to speed up rendering quite a lot.
with a HDRI on a own sphere you skip this calculation part...
solarray
Post by solarray » Tue Mar 15, 2011 6:16 am
Isn't it implemented in indigo 2.6.1 yet? In indigo blender exporter I can't find any texture channel in 'light emission' material settings. Than I tried to create an external material with indigo material editor and enabled in the emission section a hdri (.exr) texture, and linked this external material to the plane but indigo says 'Scene must contain at least one light source' !
Thanks for the hint but that was not my purpose.
cheers
Post by Zom-B » Tue Mar 15, 2011 6:24 am
solarray wrote:Isn't it implemented in indigo 2.6.1 yet?
Textured emitter Materials are quite long time integrated in Indigo!
solarray wrote:In indigo blender exporter I can't find any texture channel in 'light emission' material settings...
I'm no blender user, so I can't help you there, maybe a quick look in the belndigo manual can help, or give it a try in the blendigo subforum.
(or even better some blenderhead gives a quit reply here!)
solarray
Post by solarray » Tue Mar 15, 2011 7:19 am
Ah ok it need to be set as diffuse color texture with light emission enabled, thanks.
