Problem uploading image.
I'm trying to post in finished artwork and am getting the invalid file message when I try to add the render, it's a jpeg 1310 x 836.
Re: Problem uploading image.
Is it under 4mb (I think that's the limit). And is the file extension .jpg, or jpeg.
And.. is it in the right color modes? 8bit (I think..) and RGB (not CMYK)
The image is smaller than most I have posted in the past and in same format, not sure whether problem is my end or with site at the moment.I 'll try again later.
I'm getting a different error... that the image dimensions can't be determined. I guess you guys moved everything to a new server? Perhaps php wasn't compiled with all of the modules your forum package needs? We just did a big server move at work, and problems like that kept cropping up on code were were developing.
Also the galleries are full of MySQL errors. Server moves are never fun, especially with different versions of php and mysql have different strictness on syntax. Good luck.
