community need for renderings
Hi everyone,
I start a new post because I need the community to launch several rendering. I have 12 images format 4200x3200 pixels, I'll be fine with a render farm unfortunately they are on 3.4.16 out all my scenes were implemented in the 3.6.11 release ... so incomptatible!
If I was not pressed for time I would have run on my machine, unfortunately I owe everything to Friday.
Does anyone have the ability to calculate a stage?
Thank you in advance for your help.
C4DR11.5-R12 user-Quad core Intel Xenon 2X2,26 GHZ
Zbrush 4
Zbrush 4
- Polinalkrimizei
Re: community need for renderings
So you want to render on for example my machine?
Are you sharing a .pigs via dropbox or e-mail? Or do you want to establish a VPN?
You can send me a pm, but I probably won't be able to start until Wednesday evening MEZ.
Good luck!
Good luck!
Hello,
thank you very much for your offer of help!
I'm going to share a dropbox folder with all scenes.
If others are likely to be able to help me thank you also to specify the stage that you take to avoid it done in double
thank you so much!
thank you so much!
Zbrush 4
Zbrush 4
thank you so much!!
I prepare all the scenes tonight with the right parameters and I post this evening or tomorrow morning Dropbox link
Olivier
Olivier
Zbrush 4
Zbrush 4
I just create a folder with all the scenes.
Here is the link:
https://www.dropbox.com/sh/lsxwfs6yl8cmz9g/rmW79xLZfv
Those in red are not yet done, those in green are made or being calculated.
thank you to the color update
Thanks!!!
Olivier
Here is the link:
Thanks!!!
Olivier
Zbrush 4
Zbrush 4
I just realize that the output size was not taken into account when the enregistremet scenes.
Do not forget to locker ratio and to 4200x3200
Zbrush 4
Zbrush 4
I have one going with Indigo 3.6.18:
150653386_2
Using bi-directional Path tracing.
Little suggestion though. We cannot really see what's in the scene until we start rendering . A little pointer per scene what may be the best render mode will help avoid unnecessary and time consuming experimentation.
I just picked one as I did not see any colors. Also in what format you need these back. Just plain PNG ?
150653386_2
ATI Radeon HD 5750M 1024 MB
OS X 10.10.3 Yosemite
I don't see any color at all O_o
What scene should I take???
so I randomly picked "150653392_2_hd.pigs" and render in PT with help of GPU
thanks guys!!
this is the update of list
red means that the scene is not rendered.
Yellow means being rendered
and green rendering is finished
Zbrush 4
Zbrush 4
I'm beging 150653385
Olivier
Olivier
Zbrush 4
Zbrush 4
I'm on 150653380_2_hd but I only have RT so no IES profiles. Let me know if that's ok.
Hey!!
There is not IES profils
ok for this visual
Thanks you!!!
ok for this visual
Thanks you!!!
Zbrush 4
Zbrush 4
I'm begining 84003204_2_09_07_13_hd.pigs
this is the list update
Zbrush 4
Zbrush 4
