I cant even do sketchup tutorial render because of errors!
Tutorials/guides/tips on how to use Indigo and the Indigo exporters
3 posts • Page 1 of 1
gogeta14
Post by gogeta14 » Sun Jun 21, 2009 6:12 pm
Hello everyone.
I'm new to using indigo, and I downloaded the SkIndigo program as well as Indigo. I also downloaded the Skindigo tutorial - getting started. However, I cant even complete the render step because I get this error message:
Error: SceneLoaderExcep: ModelLoadingStreamHandlerExcep: UV set with index 1 was exposed, but the UV set data was not provided. (In element 'mesh', around line 6, column 9)
I have searched the forums and found 2 posts with the same issue, however I do not understand why I am running into this since I am using a tutorial, which would be set up properly. I made sure that all the steps were done properly when i loaded the programs, and I also made sure both Indigo and SkIndigo were the 1.0.9 versions.
Please help me I just want to get started, it looks like a great program.
Re: I cant even do sketchup tutorial render because of errors!
Post by Whaat » Sun Jun 21, 2009 6:19 pm
Hi and welcome to indigo.
Are you sure that you are not using a 2.0.X release of Indigo? I don't think you would be getting this error message if you were using Indigo 1.0.9. (Hope I'm not wrong... :) )
gogeta14
Post by gogeta14 » Sun Jun 21, 2009 6:30 pm
Oh your right! Its the 2.0 version. Its still left on my laptop even though I thought I erased it before I loaded the older version. I will try to make sure its completely gone and see if it loads in the correct version. Thanks!
Users browsing this forum: No registered users and 72 guests
