Camera problem
chubakueno
Camera problem
I want a shot from a test building, and when I export to indigo it simply take another shot.
Re: Camera problem
You mean it changed the camera angle? Or the image dimensions? What changed?
The current view should always be the one that is exported to Indigo. Open render settings and set your image dimensions, then press 'apply changes'. Then try rendering the scene.
chubakueno
Re: Camera problem
The ZOOM is changing between the sketchup's scene and the indigo scene
Re: Camera problem
are you trying to render two-point perspective, parallel projection or photo-matched view? These modes might not render correctly.
chubakueno
Re: Camera problem
Thanks. I was rendering on Isometric. Now it works.
