Texturing problems
2 posts • Page 1 of 1
Sehltahn
Texturing problems
Post by Sehltahn » Tue Jul 22, 2008 3:38 pm
Hey,
I'm new to Indigo (as you can probably tell from my post count), and I'm having problems with the Skindigo plugin. I've managed to install it properly, along with indigo, and have had a few *very* basic tests work out fine. I'm now having a go at texturing.
Now, I know that before a texture will show up in a render, you need to right click on the face with the texture applied to it and choose 'UV mapping>load entities assigned to material'. I did this for a few objects, and then did a quick render to see if I'd gotten it right. Success :D! After that, I made another wall and tried to apply a texture to it. However, when I right clicked on the newly textured wall, load entities did not appear in the UV mapping list (oh, and Edit whatever DIFFUSE is missing too), so I can't get it to render with the texture applied.
Does anyone know how to fix this? I can supply a sketchup file if needed (sorry if I haven't explained my problem clearly).
Cheers,
Sel
EDIT: oh, and I'm using indigo/skindigo version 1.9.0
crojack
Post by crojack » Thu Jul 24, 2008 6:16 am
the only time you need to do the uv-mapping stuff is if you are actually uv-mapping and creating sets.
if you are creating fairly basic materials, than you don't need to do anything but edit them in the skindigo mat editor.
make sense? sounds like you are jumping in with some difficult (at least to me) stuff when maybe you should just try some pre-sets to get the hang of the program.
Users browsing this forum: No registered users and 61 guests
