Indoor lighting problem
7 posts • Page 1 of 1
Post by neo0. » Wed Jul 02, 2008 7:15 am
Post by Kram1032 » Wed Jul 02, 2008 9:50 am
uhm, oKAY?
What *if* a non-sketchUp-user would be able to help you? You should explain your problem with more details and maybe also add images. ;)
(Even if you're sure, that the problem is on the SketchUp-side.)
crojack
Post by crojack » Wed Jul 02, 2008 12:13 pm
so, what's the problem?
Post by neo0. » Wed Jul 02, 2008 1:03 pm
Sorry, I was in a rush. Basically, I can't get enough light into the room. I could increase the strength of the sun and sky. Basically im looking for recomendations.
Post by Pibuz » Wed Jul 02, 2008 7:24 pm
I don't think you can increase sun power in skindigo, never heard of that. You could simply set your camera differently: raise up the ISO value, or make the shutter speed lower (or both, if you need it). I suggest you keep a relatively high f/stop, so all your objects are in plane focus, say f/11 - f/16.
Hope this helps!
Post by Kram1032 » Thu Jul 03, 2008 7:09 am
shutter speed or ISO value should both only be issues with camera tonemapping. (Which you can use to fix your light...)
You might even be able to make the image brighter with reinhard.... Just save an igi, use violet and tweak your tonemapping until it works...
If you don't want to use Violet, trial and error will be the way to go...
kwistenbiebel
Post by kwistenbiebel » Thu Jul 03, 2008 8:30 am
Using Reinhard should fix it a little not? .. as it will level the light to acceptable err..levels.
