{Ask} How to continue a render from it's latest progress
- Blazedremedy
I just got done rendering my first serious render last night it went for about 7 hours with 4 computers but still isn't close to done. It crashed at 3:00 in the morning and I don't know how to continiue from last saved point. I have the png file of what it looked like at 3:00 but still dont know how to continue.
- cookieofdoom
- Blazedremedy
the slave machines don't require anything special in regards to getting them started, your typical network-slave startup string should work fine. the difference is the starting of the master machine in which you'll need to add the -r option. if you refer to the indigo manual it shows the string requirements for starting a resume render from the command line. then to enable network rendering add in the -n option. so, for example:
[master]
c:\indigo.exe -n wm -o z:\renders\awesomeness.png -r z:\renders\awesomeness.igi z:\igs\awesomeness.igs
[slave]
c:\indigo_console.exe -n s z:\igs\awesomeness.igs
z: is of course my shared network drive accessible by all network slaves.
hope this helps!
[master]
[slave]
hope this helps!
