WIP. Better results?
Rodrigonotor
Post by Rodrigonotor » Wed May 21, 2008 7:30 am
How can a achieve better results, I use the default settings for the render.
But a see to much grain.
indigo_v1.0.9_3
SkIndigo_1_0_9.rb
SU 6
Tanks in advance.
Rodrigonotor
another pic
Post by Rodrigonotor » Wed May 21, 2008 7:31 am
another pic
remus
Post by remus » Wed May 21, 2008 7:38 am
A good start would be to use an hdr for the background, this should give your renders a bit more context.
Another thing that will make a big improvement is adding bumpmaps to the walls and pavement. Might also be worth toning down the white a bit while your at it.
Rodrigonotor
Post by Rodrigonotor » Wed May 21, 2008 7:58 am
tanks for your answer, but I refer to the quality of the image, in the gallery I see very good images (quality... no grain, no blur, etc)
remus
Post by remus » Wed May 21, 2008 8:01 am
Ahhhh, i get you now.
Well to do this you jsut need ot leave it running for longer. It would also help to tone down the whites a bit as well, as pure white gives you long render times.
Post by Kram1032 » Wed May 21, 2008 8:06 am
about the blur: That's related to DoF and Filter settings....
Else, I'd say... Change your whitepoint to get a warmer appearance and further: Inform yourself (Forum Search !!) ("!!!!") (!) about which setting does what. ;)
Rodrigonotor
Post by Rodrigonotor » Wed May 21, 2008 8:07 am
Many tanks, i put another color, not white.
Sorry for not doing much specific and for my english.
Some of the images have at least 7-14 hrs, but I not see the difference.
Thanks again
Rodrigonotor
Post by Rodrigonotor » Wed May 21, 2008 10:35 am
Kram1032 wrote:....
I try to search which settings are best, but don't find any settings
I find this in the manual.....I think??
<config>
<renderer_settings>
<metropolis>false</metropolis>
<downsize_filter>
<!--<box/>-->
<mn_cubic>
<ring>0.2</ring>
<blur>0.6</blur>
</mn_cubic>
<!--<gaussian></gaussian>-->
</downsize_filter>
<super_sample_factor>2</super_sample_factor>
<aperture_diffraction>true</aperture_diffraction>
<post_process_diffraction>true</post_process_diffraction>
</renderer_settings>
</config>
But I don't what is the best value
Thanks for your response
ZYX
Post by ZYX » Wed May 21, 2008 12:43 pm
Rodrigonotor wrote:Some of the images have at least 7-14 hrs, but I not see the difference. Thanks again
Well Indigo takes a lot of time to produce clean image 7-14 hrs is pretty much normal for that scenes i you dont want that noise just remove it in an image editor.
Rodrigonotor
Post by Rodrigonotor » Wed May 21, 2008 2:52 pm
ZYX wrote: Well Indigo takes a lot of time to produce clean image 7-14 hrs is pretty much normal for that scenes i you dont want that noise just remove it in an image editor.
I try this. Thanks.
2 images with 2 hours
Post by Pibuz » Wed May 21, 2008 8:54 pm
Hi rodrigo!
To enhance quality i suggest you select (as someone else has told you already) a white point different from E: i often use C or D65 to get a warmer effect. Another thing i often do is to change the turbidity value, randomly (but taking care of not to reach the top value). Then, adding a touch of environment objects like trees, benches etc would be good. Instancing can be SO useful! BTW good start!
Post by OnoSendai » Wed May 21, 2008 9:04 pm
Hi Rodrigonotor,
Are you using any SSS materials, or dispersive specular materials?
I'm asking because there is some unusual colour noise in the renders.
Rodrigonotor
Post by Rodrigonotor » Thu May 22, 2008 1:53 pm
Pibuz wrote:Hi rodrigo!
Thanks Pibuz, I really don`t know nothing about the white point, I try to search what means C or D65 or E, but don`t find. I make a test with this settings.
About the enviroment I try to put a background image and make a error. I try to post the window message error.
This are my first renders with Indigo and SKindigo, I new with this.
Image whit 24:30 hours, all day long jeje
im1211330838 res.png (430.91 KiB) Viewed 8067 times
same settings, same time, little bit warmer
im1211331041 res.png (462.67 KiB) Viewed 8067 times
same setings, same time 24:30 hrs
im1211331168 res.png (500.14 KiB) Viewed 8068 times
kwistenbiebel
Post by kwistenbiebel » Thu May 22, 2008 2:00 pm
Wow, very nice progress.
The light already is nice.
As Pibuz suggested....the rest is more texturing and populating your scene with things like vegetation.
Keep it up.
Regards,
Kwistenbiebel
Rodrigonotor
Post by Rodrigonotor » Thu May 22, 2008 2:05 pm
OnoSendai wrote:Hi Rodrigonotor,
Hi OnoSendai,
Glass: specular
grass: diffuse
floor: Phong
I think what is the mistake, the walls don`t have any material, only the color by default of SU. When I try to edit the materials of the walls, don`t have options.
I post the images
SKindigo wall Options
walls options.png (29.3 KiB) Viewed 8064 times
Skindigo glass options
glass options.png (51.69 KiB) Viewed 8064 times
Users browsing this forum: Bing [Bot] and 71 guests
