Tutorial ("Getting Started") Lighting
2 posts • Page 1 of 1
rchapman
Post by rchapman » Mon Apr 21, 2008 1:56 pm
Hey guys,
I'm currently doing the tutorial "Getting Started". I think it's an older version of SkIndigo but it has this light on a wall, and you have to select a 100W Incandesent bulb and what not, it's a blackbody light, set environment to black, and then render it.
Because of the different versions, it took me awhile to find the way to select the things i needed to, as the tutorial is "out of date" so to speak.
So, i eventually did what it told me to, and on the next tutorial page in SU, it shows what the rendering should look like. and my rendering looks nothing like it...it's just a wall that's brighter at the center than the edges, and the light isn't even showing up.
what did i do wrong?
SkIndigo_09 Getting Started.jpg (245.94 KiB) Viewed 2962 times
SkIndigo_09 Getting Started(2).jpg (167.91 KiB) Viewed 2962 times
rchapman
Post by rchapman » Tue Apr 22, 2008 5:38 pm
---SOLVED---
don't know what i did, i don't think i applied changes when i checked one of the options. but it worked
