section cut renders
4 posts • Page 1 of 1
bbqinking
section cut renders
Post by bbqinking » Tue Apr 15, 2008 11:00 pm
I've saved a scene in sketchup which is a section cut through the model. When I try and render, it renders the whole building rather than the view I want.
Is there a way round this or do I have to delete all the model which is in the way of the view I want to render?
thnx
8)
crojack
Post by crojack » Thu Apr 17, 2008 4:19 am
I don't think there is a way to render sections, although it would be awesome if there was-
@Whaat, hint hint :D
anyways, I think there is a ruby script that would make a group out of a section cut, and than you could put that group on a layer and turn the layer off. I haven't actually tried this but that was sort of the flow I was thinking about.
Good luck and post up some stuff if you do it.
Post by Whaat » Thu Apr 17, 2008 4:54 am
I actually thought of way to do this a couple of days ago. Once I get some time, I'll look into it. Don't hold your breath, though. This might never happen.
bbqinking
Post by bbqinking » Thu Apr 17, 2008 10:56 pm
crojack.
I'd considered that as a workable option and will try it out!
whaat.
it would be a great additional feature to indigo if you can get this to work. I stumbled with the same issue on maxwell.
thnx for your help!
bbq :wink:
