Instancing proxies:...export memory overflow [Solved]
7 posts • Page 1 of 1
kwistenbiebel
Post by kwistenbiebel » Tue Feb 12, 2008 3:09 pm
hi Whaat,
I am trying the instancing/proxies method which you explained in that (wonderful!) tutorial SU file. All works well setting it up (trees).
I end up with a scene with one tree and the rest are simple cubes ('dummies') so I can pan and zoom without any lag in SU.
However, at export, sketchup chokes.....during the export phase I can see my RAM memory usage go up to the full 2GB I have installed on my PC.
At the moment that Indigo starts up (after 20 minutes or so) , the software comes to a stall and I see a (blank) Indigo window showing up with 'visual basic ...' in the title. (crash?)
Maybe I am doing something wrong?
Cheers,
Kwistenbiebel
ps: @Whaat: check SCF as I posted the 'naked runner' in your 'subdivide and smooth' thread.
kwistenbiebel
Post by kwistenbiebel » Tue Feb 12, 2008 4:15 pm
It seems that I didn't right click all the 'dummy' components to 'enable instancing'.
Enabling it for all the dummies fixed it !
Post by Whaat » Tue Feb 12, 2008 4:44 pm
Cool! :D
Nice to see someone finally use this feature!
kwistenbiebel
Post by kwistenbiebel » Thu Feb 14, 2008 3:10 am
My first experiment with instancing/proxies.
Actually it is very easy to use.
Some Xfrog 'dummies':
Post by Pibuz » Thu Feb 14, 2008 8:03 pm
Well done Kwisten! :D :D
Very nice field you have! How did you make the terrain? It's a very nice texture!
Instancing is a very nice feature, indeed: glad you were able to fix it (i always expect only great things from you :D )
kwistenbiebel
Post by kwistenbiebel » Fri Feb 15, 2008 5:29 am
Thanks Pibuz.
Glad to see you around here :)
I downloaded the ground texture from www.cgtextures.com and projected it on a 'sandboxed' ground plane.
crojack
Post by crojack » Fri Feb 15, 2008 9:52 am
kwisten,
would you mind saying how you got the xfrog trees into sketchup?
thanks
