CoolColJ
by CoolColJ » Fri Sep 21, 2007 12:00 pm
http://sketchup.google.com/gsu6/download.html
be aware...
The uninstall process for previous releases will delete any user-created or user-modified files stored in LayOut's Default Templates or Default Scrapbooks folders. If you want to keep these files when uninstalling a previous version, navigate to the C:\Documents and Settings\All Users\Application Data\Google\Google SketchUp6 directory, and move the appropriate scrapbook and template files to a different folder. You can move them back to their original directory after you have completed the uninstall process.
When you upgrade to the latest release, you will lose any changes that you've made with LayOut's Customize Toolbar function (new toolbars, customized icons, etc). You will also lose any customizations you may have made to the Tray system (the Windows on the right side of the screen). Unfortunately, there is no workaround for this.
xrok1
by xrok1 » Fri Sep 21, 2007 1:21 pm
whats new about this? its ver.6
ribo
by ribo » Fri Sep 21, 2007 6:01 pm
It is only a service release for bug fixing. After installation, works fine for me. Skindigo latest version has no problems.
Regards
CoolColJ
by CoolColJ » Wed Oct 03, 2007 10:17 am
anyone notice any weird stuff happening with the new version?
I've had situations where having an exit portal in a scene caused the room to emit omni directional lighting. Removing the exit portal made the sun come into the room as normal. And having the exit portal half open allowed sun into the room
