Cyberdactyl
by Cyberdactyl » Sat Jun 23, 2007 3:04 am
At home I was able to upgrade from v0.6l and run v0.7test7 along with the SU rb.
At work I get;
"This application failed to start because msvcp71.dll was not found. Re-installing the application may fix this problem"
I've uninstalled SU, removed all versions of Indigo, rebooted and reinstalled everything and still get the message.
Any ideas?
PhilBo
by PhilBo » Sat Jun 23, 2007 5:19 am
Yeah. Search for that DLL on Google. You will find various places to download a copy. Put it in your Indigo directory. Poof....problem gone. At least that's how it worked for me when I installed it in Linux.
Cyberdactyl
by Cyberdactyl » Sat Jun 23, 2007 5:52 am
Problem is Skecthup HAS the file.
But I did try replacing it thinking it might be corrupt and doing so changed nothing.
by suvakas » Sat Jun 23, 2007 6:32 am
What gives you the error SU or Indigo?
If it is indigo, then copy msvcp71.dll into your Indigo dir like PhilBo suggested.
Cyberdactyl
by Cyberdactyl » Sat Jun 23, 2007 5:33 pm
Put in the Indigo directory as well. . .no dice.
Yes, I'm dumbfounded since it worked immediately on my PC at home.
PhilBo
by PhilBo » Mon Jun 25, 2007 12:37 pm
I found that you needed both to work:
MSVCP71.dll
and
msvcr71.dll
Try to add the other and see if it helps.
Cyberdactyl
by Cyberdactyl » Tue Jun 26, 2007 12:16 am
Thanks Philbo. . .you're my hero.
Putting both the dlls in the Indigo directory did the trick.
