ciccio
by ciccio » Thu May 31, 2007 10:31 am
Hello to all, I to be new of the forum of indigo. I to ask one gentility like using alpha map (clip mapping) in indigo?
example the leaf
I use Sketchup
- nuovo-1.jpg (31.88 KiB) Viewed 15354 times
- im1180563784.jpg (83.59 KiB) Viewed 15354 times
by Zom-B » Thu May 31, 2007 7:12 pm
Welcome to the Forum Bruce Lee!
Take a look at
this tutorial,
consider next time to post your threads in Sub Forums they fit to
Here is the SketchUp sub forum...
ciccio
by ciccio » Fri Jun 01, 2007 12:25 am
tank very much ZomB
Grazie!
ciccio
by ciccio » Fri Jun 01, 2007 12:37 am
to be tutorial for blender. to be the same thing SU - Blender?
manitwo
by manitwo » Fri Jun 01, 2007 12:46 am
*moved*
by Kram1032 » Fri Jun 01, 2007 2:20 am
*moved*?
ciccio
by ciccio » Fri Jun 01, 2007 2:24 am
by Kram1032 » Fri Jun 01, 2007 2:27 am
Sorry, I can't answer the question, as I don't use Sketchup myself, but
*moved*
Has this been in an other forum, before?
by Whaat » Fri Jun 01, 2007 2:30 am
Welcome, ciccio!
To use Alpha Maps in SkIndigo 0.7.1, you need to create two materials in Sketchup.
- Material #1 ("Leaf") has the leaf texture applied to it.
- Material #2 has the alpha map applied to it.
- Set Material #2 type to 'Blend'
In the 'Blend' settings:
- Set Material A to "None" (will replace the black areas of the alpha map)
- Set Material B to "Leaf" (will replace the white areas of the alpha map)
Use the Sketchup Paint Bucket to paint your faces with Material #2 (the Blend Material)
Make sure you are not using version 0.6. It does not support alpha maps.
Attached is a Sketchup file showing an example of using an alpha map to create grass.
- GrassPatch.zip
- Alpha mapped grass (included with SkIndigo 0.7.1)
- (134.71 KiB) Downloaded 336 times
ciccio
by ciccio » Fri Jun 01, 2007 4:15 am
tank very much Whaat
Grazie!
A_Minima
by A_Minima » Fri Jun 01, 2007 4:20 am
Not the thread subject but studying the Whaat's file : are you a French-speaking person Whaat ? (regarding to your maps name for the grass map into the SU material edit menu).
manitwo
by manitwo » Fri Jun 01, 2007 4:38 am
*moved*
my god, please think before posting! (if you investigate a few second in thinking and rereading you will be able to answer it yourself)
by Whaat » Fri Jun 01, 2007 4:39 am
A_Minima wrote:Not the thread subject but studying the Whaat's file : are you a French-speaking person Whaat ? (regarding to your maps name for the grass map into the SU material edit menu).
Sorry, I don't speak any French except for the few words I have picked up living in a bi-lingual country. I have some French connections, though. My brother married a girl from the west coast of France and my parents just got back from a vacation in France. I downloaded the textures and never changed the names so that's why they are French.
ciccio
by ciccio » Sat Jun 09, 2007 11:21 pm
Ok Grazie!!! Thanks of the councils
- im1181342487.jpg (421.43 KiB) Viewed 15060 times
