Hi Whaat and indigo'ers,
Would it be possible to have a different camera setup procedure for assigning viewport size and image ratio in a next release?
The current one seems to screw up my sketchup viewport (it jumps and zooms unexpectedly, banding at the sides etc,..).
I think the current setup also affects the use of other render software in combo with SU .
thanks,
kwistenbiebel
wishlist: different camera setup for skindigo
- kwistenbiebel
Re: wishlist: different camera setup for skindigo
The current camera setup advantages vastly outweigh the disadvantages IMO. It is difficult and maybe impossible to match the Sketchup image export output if you are trying to match an image that you made BEFORE setting up your Indigo camera settings. This is a Sketchup issue and I won't get into the details but let me just say that I don't know of any easy workaround at the moment.kwistenbiebel wrote: Would it be possible to have a different camera setup procedure for assigning viewport size and image ratio in a next release?
However
SAVE your view as a new Sketchup scene (page)!! If you don't want the Indigo settings to mess up your camera settings for your other rendering programs, save the scene using a new tab. Use your other tabs for your other rendering programs.
With the official version of SkIndigo 0.7 (soon to be released), you can type in an image width of zero and your render dimensions will be automatically set to your viewport dimensions (thus removing the black bars). I'm afraid that's the best I can do...
So when are we going to see some of your renders in the gallery??
- kwistenbiebel
Users browsing this forum: Baidu [Spider] and 62 guests
