SkIndigo 3.8.24 (beta)
13 posts • Page 1 of 1
Post by OnoSendai » Fri Dec 19, 2014 5:44 am
Changelog:
Improved external obj mesh support - automatically adds and converts materials from the obj and mtl files.
Fix/workaround for 'reference to deleted Entity' problem in some cases.
Minimum required Indigo version is 3.8.11.
RBZ: (Works on all platforms)
http://downloads.indigorenderer.com/dis ... 3.8.24.rbz
Windows Installer:
If anyone gets a 'reference to deleted Entity' error message, please stop, write down what steps you just took, and send me the .skp scene! (support@indigorenderer.com)
nosek1995
Re: SkIndigo 3.8.24 (beta)
Post by nosek1995 » Sun Dec 21, 2014 11:31 pm
It's not working. I installed everything, following the instructions. I have SketchUp 2015. Everytime I open it a thing like that pops out:
Error Loading File C:/Users/Właściciel/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/skindigo/skindigo_core.rb
Error: #<LoadError: No such file or directory -- C:/Users/Właściciel/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/skindigo/SkIndigoUVS.rb>
C:/Users/Właściciel/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/skindigo/skindigo_core.rb:12:in `load'
C:/Users/Właściciel/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/skindigo/skindigo_core.rb:12:in `<top (required)>'
C:/Program Files/SketchUp/SketchUp 2015/Tools/extensions.rb:197:in `require'
C:/Program Files/SketchUp/SketchUp 2015/Tools/extensions.rb:197:in `load'
C:/Users/Właściciel/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/skindigo.rb:19:in `register_extension'
C:/Users/Właściciel/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/skindigo.rb:19:in `<module:SkIndigo>'
C:/Users/Właściciel/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/skindigo.rb:4:in `<top (required)>'
Help me! Please!
Post by Pibuz » Tue Dec 23, 2014 3:18 am
99 over 100% the problems are caused by the non-english characters on the username you use.
Post by OnoSendai » Tue Dec 23, 2014 3:22 am
Pibuz wrote:99 over 100% the problems are caused by the non-english characters on the username you use.
Unicode support should be working properly in SketchUp 2015 though.
Post by Pibuz » Tue Dec 23, 2014 3:24 am
..reading from the second line "C:/Users/Właściciel/" sketchup seem not to be finereading the path..
Post by OnoSendai » Tue Dec 23, 2014 4:19 am
Just tried with a Unicode user name, indeed there are problems with SketchUp 2015, sorry about that, will fix!
Post by OnoSendai » Wed Dec 24, 2014 2:12 am
This is actually quite tricky to fix due to many bugs in Ruby. (the language used for SketchUp plugins)
Still working on it..
nosek1995
Post by nosek1995 » Wed Dec 24, 2014 2:49 am
Ok I'll dig into it and see what will happen when I change folder names :) Thanks for the help ;)
snorky
Post by snorky » Sat Dec 27, 2014 9:24 pm
just a test...
why does the scattered tree have wrong texture?
Aflac
Post by Aflac » Wed Dec 31, 2014 7:32 am
I too am having the problem of scattered objects not having the correct materials. In my case the scattered objects are linked obj files and they are rendering with the 'default' material.
Post by OnoSendai » Fri Jan 09, 2015 5:41 am
nosek1995 wrote:It's not working. I installed everything, following the instructions. I have SketchUp 2015. Everytime I open it a thing like that pops out:
Help me! Please!
Please try the new build here and see if it helps: http://www.indigorenderer.com/forum/vie ... 17&t=13417
Cheers!
Post by OnoSendai » Wed Jan 14, 2015 4:47 am
snorky wrote:just a test...
Snorky: Please try this build: http://www.indigorenderer.com/forum/vie ... 17&t=13424
and tell me if it fixes this problem.
If it doesn't, please send me the .skp (and any external mesh files etc..)
Post by OnoSendai » Wed Jan 14, 2015 4:48 am
Aflac wrote:I too am having the problem of scattered objects not having the correct materials. In my case the scattered objects are linked obj files and they are rendering with the 'default' material.
please try http://www.indigorenderer.com/forum/vie ... 17&t=13424
