Subdivision question
cotty
Post by cotty » Wed Jul 11, 2012 7:19 pm
I modeled a wine glass for another forum and wonder why the glass is not as smooth as expected. I used subdivision up to 6 but didn't get a smooth result. Any ideas what I am doing wrong in this case?
Thanky for your help!
Cotty
Pikadili89
Re: Subdivision question
Post by Pikadili89 » Wed Jul 11, 2012 8:09 pm
You could smooth it with increasing segments of the circle you used for path. Thats the modeling solution, I am not sure how to do it with just indigo. Hope I helped a lil bit :)
Post by OnoSendai » Wed Jul 11, 2012 9:35 pm
You could also try modelling the wine glass with quads. Should help.
Post by lycium » Wed Jul 11, 2012 11:36 pm
I don't think SkIndigo exports quads unfortunately :oops:
Post by CTZn » Thu Jul 12, 2012 12:29 am
To go a bit into details about the issue with triangles here, is that some vertices have 4 incoming edges when others got 8. This creates a tension you will not get rid of without editing the geometry.
It could be triangles if all diagonals had the same direction.
cotty
Post by cotty » Thu Jul 12, 2012 7:33 am
lycium wrote:I don't think SkIndigo exports quads unfortunately :oops:
There are some possibilities, but I used Artisan for subdivision and therefore have no influence on the triangles (maybe Whaat have an idea?!)
CTZn wrote:To go a bit into details about the issue with triangles here, is that some vertices have 4 incoming edges when others got 8. This creates a tension you will not get rid of without editing the geometry.
I tried some different subdivisions but until now I was not able to pruduce an equal-incoming-edges version (e.g. 6/4 edges):
I wonder why I didn't noticed this problem before...
cotty
Post by cotty » Fri Jul 13, 2012 8:20 am
New version with quad mesh...
Thank you for the helpful hints!
Post by OnoSendai » Fri Jul 13, 2012 8:26 am
Sweet render!
To the gallery pls!
cotty
Post by cotty » Fri Jul 13, 2012 8:42 am
OnoSendai wrote:Sweet render!
To the gallery pls!
Thank you! I will let it cook another night and will upload it nearly without fireflies :wink:
cotty
Post by cotty » Sat Jul 14, 2012 1:07 am
Thirst for more ...
Voytech
Post by Voytech » Sat Jul 14, 2012 1:09 am
cotty wrote:Thirst for more ...
Jaw drop....
galinette
Post by galinette » Sat Jul 14, 2012 1:28 am
Wow! Nice!
Maybe just some bubbles missing? Instancing lots of spheres should not make the scene too heavy
Etienne
Eclat-Digital Research
http://www.eclat-digital.com
cotty
Post by cotty » Sat Jul 14, 2012 2:28 am
galinette wrote:Wow! Nice!
Etienne
I will have a look at this. How do I add bubbles? Only little spheres in the beer or do they need a special material, normal direction, ...?
Post by lycium » Sat Jul 14, 2012 2:41 am
It's Friday, so I suggest:
1. Get a beer
2. Look at bubbles while drinking beer
3. Go home (carefully if you've "studied" a few)
4. Model bubbles
8)
Post by Pibuz » Sat Jul 14, 2012 3:18 am
cotty wrote:New version with quad mesh...
Ehy Cotty! How did you solve the tri-mesh issue? How did you model that glass, in the end?
