Hi to you all,
I've updated my indigo/skindigo to 3.0.14/3.0.14 on Win7 32 and i get a weird error by now, on models i was able to render with 2.6 versions.
I get the message "ObjectExcep: Emitting object has zero total luminous flux." regardless of the presence of emitting objects...
Do any of you have an idea of what's going on ? I've uploaded a model that has this problem.
3.0.14 skindigo : ObjectExcep: Emitting object has zero tota
- principe v2 v6.rar
- (4.22 MiB) Downloaded 182 times
Re: 3.0.14 skindigo : ObjectExcep: Emitting object has zero
Hi, beside warnings about two missing textures from your scene, the pipes render as emitters without this error.
I was using SkIndigo 3.0.15 though, maybe there was a bug with this in SkIndigo 3.0.14 ?
That's weird, i was using 3.0.15 then reverted to 3.0.14 as i thougth the issued lied in the beta status of the 3.0.15 but since you do not have the problem... Other than that, it looks like i have several other issues (unable to use shader bump or displace, geometrical disposition of many objects gets changed once in indigo...)
I'll revert to 2.6 to see if it fix all this, then i'll come back to 3.xx when I have no deadline pending.
Thanks for the answer though !
Mmh, I don't have much personal experience with this but given the discepancies in result we are having, I would reinstall SketchUp first and then the latest renderer and exporter versions. Sketchup seems in cause there, to me that is.
Let us know if using 2.6 fixes the issue...
It looks like SU was responsible for the trouble, yet i have some issues with 3.0.14 (geometry not where it is supposed to be).
I'd like to revert to 3.0.12 (last version working correctly -- as far as I remember), but I can't find the skindigo pluggin 3.0.12... Does anyones have it ?
