I am new to indigo, and have both indigo &skindigo at versions 2.4.13 on sketchup 8. i keep encountering this problem every time i try to render this particular file. please help!!
SceneLoaderExcep: Failed to load texture '/Volumes/Indigo/Indigo.app/Contents/Resources/TX_default/photon-rug_cream.png': LibPNG error: IDAT: CRC error
Indigo version: Indigo Renderer v2.4.13, OS X 64-bit build.
Exporter: SkIndigo version:2.4.13
Platform: i686-darwin8.10.1
Author: Dale Martens (Whaat)
Description:
Date created: Fri Apr 08 12:51:57 -0400 2011
Please contact support@indigorenderer.com.
Rendering Issue
Re: Rendering Issue
I hope Whaat will show up soon and solve your issue. I can't help you, sorry.
Re: Rendering Issue
That does not sound like an exporter issue.
I seems that the PNG image is corrupt and can't be read. Try to eliminate it from the scene and see if that helps.
Looks like you're on a mac. Are you able to open the image with Preview ?
Re: Rendering Issue
If its only that particular file that causes the issue, perhaps its something wrong with that particular png. Try deleting it from your model and replacing with the default material and see if that works.yelfawal wrote:I am new to indigo, and have both indigo &skindigo at versions 2.4.13 on sketchup 8. i keep encountering this problem every time i try to render this particular file. please help!!
Description:
Re: Rendering Issue
Hi all,
Just like to say that all IDAT and CRC png handling errors will now be just warnings (and so the render will work just fine) for the next Indigo release.
- pixie
Re: Rendering Issue
when? When? WHEN?OnoSendai wrote:Hi all,
Re: Rendering Issue
Will it be called Indigo as well? There are so many changes you're prophetizing!OnoSendai wrote:Hi all,
