SkIndigo Progress Updates (Whaat's Development Blog)
@ dougal2:
How many frames of this did you actually render? 'cause if you do it right, you only need to render the diamond rotating from one edge to the next....
Cauchy_B-including animations have two big problems:
1) The long time it needs that a single frame actually shows smooth caustics
2) The high change of caustics when the light hits the diamond in a slightly different angle...
I wonder if you would be crazy enough to render it at 200h/frame? O.o
I must admit, I haven't been working on SkIndigo as much lately. However, I have been busy with other projects that SkIndigo users may be interested in.
I was so tired of SU renders being criticized for being too low-poly that I created a subdivision modelling plugin. Now we should finally see some silky smooth SU->Indigo renders!
Here's a link to the release announcement:
http://www.sketchucation.com/forums/scf ... 24&start=0
Cool tutorial video by chippwalters:
http://www.screencast.com/t/CCpcWqzOWU
Development 'blog':
http://www.sketchucation.com/forums/scf ... 180&t=5687
New project:
http://www.sketchucation.com/forums/scf ... 180&t=9435
Not to worry...I won't be abandoning SkIndigo. I will try to keep it up to date with the latest Indigo as much as possible.
Development 'blog':
New project:
- kwistenbiebel
subdivide and smooth plugin
Very cool plugin, Whaat .
As you see, I already had my share of fun with it.
Modeled using the subsmooth plugin combined with the FFD plugin :
Here's a preview of the next SkIndigo. Hopefully, I can release it within a week. Some major surgery has occurred in the material editor. Take note of the following:
- color picker interface
- shader implementation
- new streamlined displacement interface
- light layer selection
- emitting materials
- screen.png (652.17 KiB) Viewed 4825 times
- kwistenbiebel
Looks amazing. I can't wait to try it.
That improved displacement interface, light layer assignment, and shader support is very much welcomed.
Does the color picker only work for emitting materials?
I ask this because in your image the color picker points at 'base emission'.
Right now, only base emission uses the color picker. I might add it to other attributes (SSS, G-Spectrum) in the future if users like the interface. It works a bit different than a typical color picker. You have to edit the color using the picker first, and then click on the swatch to update it. (It's really easy...just different)kwistenbiebel wrote: Does the color picker only work for emitting materials?
