SkIndigo 3.8.6.1
Re: SkIndigo 3.6.8.1
Ono, did you have any joy with that scene bug? Is it a Skindigo issue or something I've done?
It exports for me. I need to make a few more changes then I'll put up a new build.bubs wrote:Ono, did you have any joy with that scene bug? Is it a Skindigo issue or something I've done?
much appreciated.
Hi bubs, sent you an email, did you get it?
yep, I'll have a look now.
Hi bubs, I updated the build, can you let me know if it works, thanks!
I'm still getting this error message... Mystery... It does seem to be only this scene however, I've tried a lot of others and have no issues...bubs wrote:A problem occurred with the scene:
Scene parsing error: While processing node 'Group#11', UID 925: Referenced node (UID 481) did not have type SceneNodeMaterial
Found the problem
but don't know why it is a problem
It's the LinkedIGM Arch glass in the windows. I used a LinkedIGM for Arch Glass to avoid the need to check the box within Indigo every time... It always worked fine with the previous Skindigo.
Ok, thanks for tracking it down, will fix!
Updated the builds with a few fixes and improvements.
Bubs: the scene renders for me, using all linked IGMs.
There are still a few maps missing.
Dunno... I changed that one LinkedIGM and it works. Maybe just a buggy material... Thanks for the efforts tho! Really appreciated.OnoSendai wrote:Bubs: the scene renders for me, using all linked IGMs.
Using SkIndigo 3.8.6.1 instancing is not working anymore
24 hours isn't enough
http://www.werkraum3d.com
Hi Lape, what kind of instancing are you referring to? Component instancing or proxy instancing?lape wrote:Using SkIndigo 3.8.6.1 instancing is not working anymore
Component instancing does not work.
I know, I should not install a beta when I have to finish a project, but now I reinstalled 3.6.28.3 and get this:
SkIndigo version: 3.6.28.3
SketchUp version: 14.1.1282
Ruby platform: i386-mingw32
Error during processing: BlendMaterialUndefined
C:/Users/Knopp/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/skindigo/skindigo_core.rb:8533:in `write_mat'
C:/Users/Knopp/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/skindigo/skindigo_core.rb:8282:in `export_material'
C:/Users/Knopp/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/skindigo/skindigo_core.rb:968:in `block in export'
C:/Users/Knopp/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/skindigo/skindigo_core.rb:967:in `each'
C:/Users/Knopp/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/skindigo/skindigo_core.rb:967:in `export'
C:/Users/Knopp/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/skindigo/skindigo_core.rb:11606:in `block in <top (required)>'
-e:1:in `call'
any help?
-e:1:in `call'
any help?
.. the error only shows as soon as I use an environment map and add sun...
Users browsing this forum: Semrush [Bot] and 11 guests
