Using an exr image in sketchup
The water is a plane that is crumpled ( I modelled it in Cheetah3d than exported it as an 3ds file.) The material is a standard glass material. There's no thickness, but I didn't need the refraction.
The plane has lots of polygons, but I'll try to post the .skp file when I get back to work.
edit: OK. Here's the FILE
Regards,
Peter
Regards,
Peter
Mac Pro 3GHz quadcore, iMac dualcore 2 GHz, Vectorworks 2008, Sketchup 7 Pro, Indigo Renderer, Cheetah3d 4.6.3, OS X 10.5.6
Thank you Peter!!!!!!!
I tried pool water with a bump map and for most shots the veiwing angle was too low and the water just looked blotchy. That was using glass with thickness!
We need some smart cookie to devise a way to surface water and windows with a single plane material to avoid the refractive and time consumption that glass can lead to!
Cheers all!!! Richard
