Light problem
4 posts • Page 1 of 1
Latetzki
Light problem
Post by Latetzki » Thu Sep 11, 2008 12:27 am
I'm trying to set light to my model but when I start rendering, that area I selected for light is just black. No light at all. I made new white material for light and double-clicked material and Indigo window shows up, then I select light from the Assign Preset. That's pretty much all I did. What went wrong? :cry:
Post by Pibuz » Thu Sep 11, 2008 11:18 am
uhm..
Check your normals, first of all.. White side facing outside the geometry, not inside....
Then..do you use camera tonemapping? Because, if so, try setting a greater ISO value, or increase the exposure time consistently.
Other thing: are you using the default sky system? because, for making a simple light study scene you better have a black background..
alexccmeister
Post by alexccmeister » Fri Sep 19, 2008 6:29 pm
Hi, Where do I set the background black in SU? Can't seem to find it. Thanks.
Alex
cpfresh
Post by cpfresh » Fri Sep 19, 2008 7:44 pm
its in the environment tab on the indigo settings dialog.
